path: root/testsuites/psxtests/psxshm01 (follow)
* config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORSSebastian Huber2019-12-191-1/+1
| | | | | | | Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753.
* testsuite/psxtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-22/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* psxtests: Relax shared memory testsSebastian Huber2017-01-251-9/+12
| | | | | | There is currently no proper mmap() implementation. Update #2859.
* posix: shared memory supportGedare Bloom2017-01-134-0/+142
Add POSIX shared memory manager (Shm). Includes a hook-based approach for the backing memory storage that defaults to the Workspace, and a test is provided using the heap. A test is also provided for the basic use of mmap'ing a shared memory object. This test currently fails at the mmap stage due to no support for mmap.
