Replace _Objects_Name_to_id_string() with _Objects_Get_by_name() since
all users of this function are interested in the object itself and not
the identifier.
Use the object allocator lock to protect the search.
Update #2555.
* psxsem01/Makefile.am, psxsem01/init.c, psxsem01/psxsem01.scn,
psxtimer01/psxtimer.c, psxtimer01/system.h, psxtimer02/psxtimer.c:
Improved so coverage is better.
* psxsem01/init.c, psxsem01/psxsem01.scn, psxtimer/psxtimer.c,
psxtimer/psxtimer.scn: Add optional managers to Makefiles. Clean up
test cases so last output line follows END OF pattern. Make sure test
case all run. All tests appeared ok on sis.
