Updates #3053.
Rename this header file to later move <t.h> to <rtems/test.h>. The main
feature provided by <rtems/test-info.h> is the output of standard test
information which is consumed by the RTEMS Tester.
Update #3199.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
POSIX rwlocks are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3115.
* psxrwlock01/main.c, psxspin01/main.c: Now accounts for extra stack
requested for initialization task.
* include/pmacros.h, psx01/init.c, psx01/system.h, psx13/main.c,
psxbarrier01/main.c, psxchroot01/main.c, psxfatal_support/init.c,
psxfile01/main.c, psxfile01/test.c, psxmount/main.c, psxrdwrv/main.c,
psxreaddir/main.c, psxrwlock01/main.c, psxspin01/main.c,
psxstat/main.c, psxtime/main.c: Change TEST_INIT to CONFIGURE_INIT.
Make tmacros.h available to all POSIX tests. Add a clock_settime case
for < 1988.
* psxrwlock01/main.c, psxrwlock01/test.c: Improve rwlock test to
include normal blocking and unblocking on timeout.
* psxrwlock01/.cvsignore, psxrwlock01/Makefile.am, psxrwlock01/main.c,
psxrwlock01/psxrwlock01.scn, psxrwlock01/test.c,
psxspin01/.cvsignore, psxspin01/Makefile.am, psxspin01/main.c,
psxspin01/psxspin01.scn, psxspin01/test.c: New files.
