path: root/testsuites/psxtests/psxpasswd02 (follow)
* testsuite/psxtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-23/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* psxpasswd02: Use floating-point taskSebastian Huber2018-01-191-0/+1
| | | | This test uses sprintf().
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEMSebastian Huber2014-12-161-1/+0
| | | | This define was superfluous, undocumented and used inconsistently.
* libcsupport: Use POSIX key for getgrent()Sebastian Huber2014-11-201-0/+2
* tests/psxtests: Use <rtems/test.h>Sebastian Huber2014-03-251-2/+6
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* psxtests - Eliminate missing prototype warningsJoel Sherrill2012-05-111-1/+6
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-113-9/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-2/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am, psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am, psxaio03/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxclassic01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxeintr_join/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am, psxfile02/Makefile.am, psxfilelock01/Makefile.am, psxgetrusage01/Makefile.am, psxid01/Makefile.am, psximfs01/Makefile.am, psximfs02/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxsignal06/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Remove obsolete optional manager capability.
* 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-06-201-0/+1
| | | | | | | | | | * Index: psxautoinit01/Makefile.am, psxbarrier01/Makefile.am, psxclassic01/Makefile.am, psxcleanup01/Makefile.am, psxfchx01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrwlock01/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am: Eliminate rtems_scn_DATA. Install *.doc to rtems_testsdir.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* 2010-08-10 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-08-102-0/+18
| | | | | | PR 1598/testing * psxpasswd02/init.c, psxpasswd02/psxpasswd02.scn: New test case added to improve coverage of getpwent.c.
* 2010-08-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-08-091-1/+0
| | | | * psxpasswd02/init.c: Remove unused variable.
* 2010-08-06 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-08-072-0/+28
| | | | | | | | | | | | | | PR 1654/testing * psx13/test.c, psx13/psx13.scn: Test case to improve testing of dup2 routine. * psxfile01/test.c, psxfile01/psxfile01.scn: New test to improve testing of fcntl routine. * psximfs01/init.c, psximfs01/psximfs01.scn: Improve testing of imfs routines. * psximfs02/init.c, psximfs02/psximfs02.scn: Improve coverage of imfs routines. * psxpasswd02/init.c, psxpasswd02/psxpasswd02.scn: New tests to improve coverage of getpwent.c.
* 2010-07-01 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-07-015-0/+261
PR 1598/testing * Makefile.am, configure.ac, psxpasswd01/init.c, psxpasswd01/psxpasswd01.doc, psxpasswd01/psxpasswd01.scn: Add testing for POSIX user database (e.g. /etc/group and /etc/passwd) access routines which are implemented in libcsupport/src/getpwent.c. * psxpasswd02/.cvsignore, psxpasswd02/Makefile.am, psxpasswd02/init.c, psxpasswd02/psxpasswd02.doc, psxpasswd02/psxpasswd02.scn: New files.
