2022-04-12 | testsuites/psxtests/psx[n-z]*: Change license to BSD-2 | Joel Sherrill | 3 | -9/+66 | |
Updates #3053. | |||||
2019-12-05 | libtest: Change expected pass state string | Sebastian Huber | 1 | -1/+1 | |
Use separator character '_' for all test states. | |||||
2019-02-18 | psxtests/psxonce01: Fix typo | Sebastian Huber | 1 | -2/+2 | |
Update #3334. | |||||
2019-02-18 | score: Avoid some deadlocks in _Once() | Sebastian Huber | 3 | -19/+80 | |
Recursive usage of the same pthread_once_t results now in a deadlock. Previously, an error of EINVAL was returned. This usage scenario is invalid according to the POSIX pthread_once() specification. Close #3334. | |||||
2018-04-10 | testsuite/psxtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 1 | -22/+0 | |
This change is part of the testsuite Makefile.am reorganization. Update #3382 | |||||
2017-11-06 | tests: Use simple console driver | Sebastian Huber | 1 | -1/+1 | |
Update #3170. Update #3199. | |||||
2017-10-28 | tests: Remove TEST_INIT | Sebastian Huber | 1 | -2/+0 | |
The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | |||||
2017-10-23 | testsuite: Use printk for all test output where possible. | Chris Johns | 1 | -0/+2 | |
- Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | |||||
2014-09-10 | psxtests/psxonce01: Use test extension | Sebastian Huber | 1 | -0/+2 | |
2014-03-25 | tests/psxtests: Use <rtems/test.h> | Sebastian Huber | 1 | -2/+4 | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 3 | -3/+3 | |
2014-03-19 | psxonce01: Add call counter to check if init function has been called. | Christian Mauderer | 1 | -13/+14 | |
2014-03-19 | psxtests: move pthread_once tests into an extra test. | Christian Mauderer | 5 | -0/+148 | |
