* | testsuites/psxtests/psx[n-z]*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 3 | -9/+66 |
| | | | | Updates #3053. | ||||
* | libtest: Change expected pass state string | Sebastian Huber | 2019-12-05 | 1 | -1/+1 |
| | | | | Use separator character '_' for all test states. | ||||
* | psxtests/psxonce01: Fix typo | Sebastian Huber | 2019-02-18 | 1 | -2/+2 |
| | | | | Update #3334. | ||||
* | score: Avoid some deadlocks in _Once() | Sebastian Huber | 2019-02-18 | 3 | -19/+80 |
| | | | | | | | | Recursive usage of the same pthread_once_t results now in a deadlock. Previously, an error of EINVAL was returned. This usage scenario is invalid according to the POSIX pthread_once() specification. Close #3334. | ||||
* | testsuite/psxtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -22/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | psxtests/psxonce01: Use test extension | Sebastian Huber | 2014-09-10 | 1 | -0/+2 |
* | tests/psxtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+4 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 3 | -3/+3 |
* | psxonce01: Add call counter to check if init function has been called. | Christian Mauderer | 2014-03-19 | 1 | -13/+14 |
* | psxtests: move pthread_once tests into an extra test. | Christian Mauderer | 2014-03-19 | 5 | -0/+148 |
