* | tests/psxtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+6 |
* | psxtests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-11 | 1 | -1/+4 |
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -1/+1 |
* | 2009-07-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-07-21 | 1 | -0/+6 |
| | | | | | * psxmutexattr01/init.c: Make test optional if tools do not support posix mutex type attribute. | ||||
* | 2009-07-17 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-17 | 1 | -0/+111 |
* Makefile.am, configure.ac: Add test to exercise pthread_mutexattr_gettype and pthread_mutexattr_settype now that the toolset enables the feature. * psxmutexattr01/.cvsignore, psxmutexattr01/Makefile.am, psxmutexattr01/init.c, psxmutexattr01/psxmutexattr01.doc, psxmutexattr01/psxmutexattr01.scn: New files. |
