path: root/testsuites/psxtests/psxmsgq04/init.c (follow)
* posix: Simplify message queuesSebastian Huber2016-05-021-1/+0
| | | | | | | | | | | | The mq_open() function returns a descriptor to a POSIX message queue object identified by a name. This is similar to sem_open(). In contrast to the POSIX semaphore the POSIX message queues use a separate object for the descriptor. This extra object is superfluous, since the object identifier can be used directly for this purpose, just like for the semaphores. Update #2702. Update #2555.
* tests/psxtests: Use <rtems/test.h>Sebastian Huber2014-03-251-2/+6
* psxtests - Eliminate missing prototype warningsJoel Sherrill2012-05-111-2/+4
* 2011-12-13 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-12-131-15/+3
| | | | * psxmsgq04/init.c: Fixed allocation of second message queue.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* 2010-10-21 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-10-211-9/+9
| | | | | | | | | | | | | | | | | | * psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c, psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c, psxcancel01/init.c, psxchroot01/test.c, psxitimer/init.c, psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c, psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c, psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c, psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c, psxstack01/init.c, psxstack02/init.c, psxualarm/init.c: Eliminate double space after parenthesis on rtems_test_assert().
* 2009-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-12-081-9/+9
| | | | | | | | | | | | | | | | | | | | | | | * include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c, psx03/task.c, psx04/init.c, psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c, psxcancel01/init.c, psxchroot01/test.c, psxclock/init.c, psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c, psxfile01/test_write.c, psxitimer/init.c, psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c, psxreaddir/test.c, psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c, psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c, psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c, psxstack01/init.c, psxstat/test.c, psxtime/test.c, psxualarm/init.c: Use rtems_test_assert() consistently instead of system assert(). rtems_test_assert() is designed to integrate into the RTEMS test suite infrastructure.
* Whitespace removal.Ralf Corsepius2009-11-301-1/+1
* 2009-08-06 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-061-12/+47
| | | | | | * psxmsgq04/init.c, psxmsgq04/psxmsgq04.scn: Tinker with test to ensure that it hits both failing to allocate memory for the message queue name and message buffers.
* 2009-08-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-051-3/+3
| | | | | * psxmsgq04/init.c: Correct typo in configuration so test does as intended.
* 2009-08-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-051-5/+13
| | | | | | | * psxmsgq04/init.c, psxmsgq04/psxmsgq04.doc, psxmsgq04/psxmsgq04.scn: Update to handle ENFILE case now that POSIX message queues and message queue file descriptors are configured separately and this error is possible.
* 2009-08-05 Santosh G Vattam <vattam.santosh@gmail.com>Joel Sherrill2009-08-051-4/+36
| | | | | | * Makefile.am, psxmsgq04/init.c, psxmsgq04/psxmsgq04.doc, psxmsgq04/psxmsgq04.scn: Exercise running out of memory while allocating the message buffers for a POSIX message queue.
* 2009-07-29 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-291-0/+6
| | | | * psxmsgq04/init.c: Add call to mq_unlink.
* 2009-07-29 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-291-0/+68
* Makefile.am, configure.ac: Add shell of new test. * psxmsgq04/.cvsignore, psxmsgq04/Makefile.am, psxmsgq04/init.c, psxmsgq04/psxmsgq04.doc, psxmsgq04/psxmsgq04.scn: New files.
