* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -2/+2 |
* | Use PRIxpthread_t to print pthread_t's. | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 |
* | Remove cast in call to fatal_posix_service_status_errno. | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 |
* | Remove unused vars. | Ralf Corsepius | 2009-10-25 | 1 | -6/+0 |
| | | | | Add missing prototypes. | ||||
* | 2009-05-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-11 | 1 | -2/+2 |
| | | | | | | | | | | * psx01/init.c, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c, psx04/task1.c, psx04/task3.c, psx05/init.c, psx06/init.c, psx07/init.c, psx08/init.c, psx09/init.c, psx11/task.c, psx12/init.c, psx13/main.c, psx13/test.c, psxbarrier01/test.c, psxcancel/init.c, psxcleanup/psxcleanup.c, psxenosys/init.c, psxmsgq02/init.c, psxtime/main.c, psxtime/test.c, psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Fix warnings. | ||||
* | 2009-01-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-01-05 | 1 | -2/+2 |
| | | | | | | * psxmsgq02/init.c, psxmsgq02/psxmsgq02.scn: Open the message queue with create option so we are sure it will get a control block and proceed to allocate other memory. Clean up screen output. | ||||
* | 2008-02-22 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-02-22 | 1 | -1/+1 |
| | | | | * psxmsgq02/init.c, psxsignal01/init.c: Corrent end of test messages. | ||||
* | 2008-02-04 Jennifer Averett <jennifer.averett@OARcorp.com> | Jennifer Averett | 2008-02-04 | 1 | -0/+65 |
* Makefile.am, configure.ac, psxmsgq01/Makefile.am, psxmsgq01/init.c: Added tests for failure path coverages. Consolidated methods used in multiple places into support routines. * psxkey01/Makefile.am, psxkey01/init.c, psxkey01/psxkey01.scn, psxkey01/system.h, psxkey01/task.c, psxmsgq02/Makefile.am, psxmsgq02/init.c, psxmsgq02/psxmsgq02.scn, psxmsgq02/system.h: New files. |
