path: root/testsuites/psxtests/psxkey08 (follow)
* tests: Use rtems_task_exit()Sebastian Huber2018-10-051-1/+1
| | | | Update #3533.
* testsuite/psxtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-23/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* psxtests/psxkey08: Avoid rtems_semaphore_flush()Sebastian Huber2016-11-232-48/+42
| | | | | | Avoid rtems_semaphore_flush() to reduce the maximum thread dispatch disabled time of this test. Remove superfluous yield and malloc(). Ensure that no resource leak occurs.
* tests/psxtests: Use <rtems/test.h>Sebastian Huber2014-03-251-2/+6
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* psxtests/psxkey08: Limit workspace sizeSebastian Huber2014-03-121-3/+9
| | | | This avoids large test execution times on targets with a big RAM.
* psxtests/psxkey08: Do not allocate task IDsSebastian Huber2014-03-121-4/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | We have a unified work area. So depending on the memory layout the task_id_p = malloc( sizeof( rtems_id ) ); rtems_test_assert( task_id_p ); or the sc = rtems_task_create( rtems_build_name('T','A',created_task_count, ' '), 1, RTEMS_MINIMUM_STACK_SIZE, RTEMS_DEFAULT_MODES, RTEMS_DEFAULT_ATTRIBUTES, task_id_p ); rtems_test_assert( (sc == RTEMS_UNSATISFIED) || (sc == RTEMS_TOO_MANY) || (sc == RTEMS_SUCCESSFUL) ); may fail. If we are unlucky then we hit the first case and the test fails.
* POSIX keys now enabled in all configurations.Joel Sherrill2014-03-072-44/+58
| | | | | | | Formerly POSIX keys were only enabled when POSIX threads were enabled. Because they are a truly safe alternative to per-task variables in an SMP system, they are being enabled in all configurations.
* Unlimited objects support for POSIX keysZhongwei Yao2013-08-064-0/+228
This patch enables unlimited model in POSIX key manger and have a decent runtime on POSIX key searching, adding and deleting operations. Memory overhead is lower than current implementation when the size of key and key value becomes big.
