path: root/testsuites/psxtests/psxkey08/init.c (follow)
* psxtests/psxkey08: Avoid rtems_semaphore_flush()Sebastian Huber2016-11-231-38/+36
| | | | | | Avoid rtems_semaphore_flush() to reduce the maximum thread dispatch disabled time of this test. Remove superfluous yield and malloc(). Ensure that no resource leak occurs.
* tests/psxtests: Use <rtems/test.h>Sebastian Huber2014-03-251-2/+6
* psxtests/psxkey08: Limit workspace sizeSebastian Huber2014-03-121-3/+9
| | | | This avoids large test execution times on targets with a big RAM.
* psxtests/psxkey08: Do not allocate task IDsSebastian Huber2014-03-121-4/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | We have a unified work area. So depending on the memory layout the task_id_p = malloc( sizeof( rtems_id ) ); rtems_test_assert( task_id_p ); or the sc = rtems_task_create( rtems_build_name('T','A',created_task_count, ' '), 1, RTEMS_MINIMUM_STACK_SIZE, RTEMS_DEFAULT_MODES, RTEMS_DEFAULT_ATTRIBUTES, task_id_p ); rtems_test_assert( (sc == RTEMS_UNSATISFIED) || (sc == RTEMS_TOO_MANY) || (sc == RTEMS_SUCCESSFUL) ); may fail. If we are unlucky then we hit the first case and the test fails.
* POSIX keys now enabled in all configurations.Joel Sherrill2014-03-071-41/+54
| | | | | | | Formerly POSIX keys were only enabled when POSIX threads were enabled. Because they are a truly safe alternative to per-task variables in an SMP system, they are being enabled in all configurations.
* Unlimited objects support for POSIX keysZhongwei Yao2013-08-061-0/+165
This patch enables unlimited model in POSIX key manger and have a decent runtime on POSIX key searching, adding and deleting operations. Memory overhead is lower than current implementation when the size of key and key value becomes big.
