path: root/testsuites/psxtests/psxkey07 (follow)
* tests/psxtests: Use <rtems/test.h>Sebastian Huber2014-03-251-2/+6
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* psxtests/psxkey07: Do not allocate task IDsSebastian Huber2014-03-121-5/+4
* psxtests/psxkey07: Limit workspace sizeSebastian Huber2014-03-121-0/+8
| | | | This avoids large test execution times on targets with a big RAM.
* psxtests/psxkey07: Account for RTEMS_TOO_MANYSebastian Huber2014-03-121-2/+3
* POSIX keys now enabled in all configurations.Joel Sherrill2014-03-072-50/+75
| | | | | | | Formerly POSIX keys were only enabled when POSIX threads were enabled. Because they are a truly safe alternative to per-task variables in an SMP system, they are being enabled in all configurations.
* Unlimited objects support for POSIX keysZhongwei Yao2013-08-064-0/+240
This patch enables unlimited model in POSIX key manger and have a decent runtime on POSIX key searching, adding and deleting operations. Memory overhead is lower than current implementation when the size of key and key value becomes big.
