path: root/testsuites/psxtests/psxkey06 (unfollow)
2022-04-12testsuites/psxtests/psx[g-m1]*: Change license to BSD-2Joel Sherrill2-6/+44
Updates #3053.
2018-10-05tests: Use rtems_task_exit()Sebastian Huber1-3/+3
Update #3533.
2018-04-10testsuite/psxtests: Merged nested Makefile.am files into one Makefile.amChris Johns1-23/+0
This change is part of the testsuite Makefile.am reorganization. Update #3382
2017-11-06tests: Use simple console driverSebastian Huber1-1/+1
Update #3170. Update #3199.
2017-10-28tests: Remove TEST_INITSebastian Huber1-2/+0
The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
2017-10-23testsuite: Use printk for all test output where possible.Chris Johns1-0/+2
- Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
2016-04-14posix: Run key destructors during thread restartSebastian Huber2-13/+100
POSIX key destructors must be called during thread restart. Just like the POSIX cleanup handlers. This ensures that the TLS object destructors are called during thread restart for example. It is important for the global construction, which uses a thread restart to run the Init task in a clean environment. Close #2689.
2014-03-25tests/psxtests: Use <rtems/test.h>Sebastian Huber1-2/+6
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns2-2/+2
2014-03-07POSIX keys now enabled in all configurations.Joel Sherrill1-35/+43
Formerly POSIX keys were only enabled when POSIX threads were enabled. Because they are a truly safe alternative to per-task variables in an SMP system, they are being enabled in all configurations.
2013-08-06Unlimited objects support for POSIX keysZhongwei Yao4-0/+217
This patch enables unlimited model in POSIX key manger and have a decent runtime on POSIX key searching, adding and deleting operations. Memory overhead is lower than current implementation when the size of key and key value becomes big.
