* | posix: Run key destructors during thread restart | Sebastian Huber | 2016-04-14 | 1 | -4/+13 |
| | | | | | | | | | | POSIX key destructors must be called during thread restart. Just like the POSIX cleanup handlers. This ensures that the TLS object destructors are called during thread restart for example. It is important for the global construction, which uses a thread restart to run the Init task in a clean environment. Close #2689. | ||||
* | Unlimited objects support for POSIX keys | Zhongwei Yao | 2013-08-06 | 1 | -0/+18 |
This patch enables unlimited model in POSIX key manger and have a decent runtime on POSIX key searching, adding and deleting operations. Memory overhead is lower than current implementation when the size of key and key value becomes big. |
