Updates #3053.
Update #3533.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
POSIX key destructors must be called during thread restart. Just like
the POSIX cleanup handlers. This ensures that the TLS object
destructors are called during thread restart for example. It is
important for the global construction, which uses a thread restart to
run the Init task in a clean environment.
Close #2689.
Formerly POSIX keys were only enabled when POSIX threads
were enabled. Because they are a truly safe alternative
to per-task variables in an SMP system, they are being
enabled in all configurations.
This patch enables unlimited model in POSIX key manger and have a decent
runtime on POSIX key searching, adding and deleting operations. Memory
overhead is lower than current implementation when the size of key and key
value becomes big.
