* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | POSIX keys now enabled in all configurations. | Joel Sherrill | 2014-03-07 | 2 | -10/+12 |
| | | | | | | | Formerly POSIX keys were only enabled when POSIX threads were enabled. Because they are a truly safe alternative to per-task variables in an SMP system, they are being enabled in all configurations. | ||||
* | Unlimited objects support for POSIX keys | Zhongwei Yao | 2013-08-06 | 4 | -0/+137 |
This patch enables unlimited model in POSIX key manger and have a decent runtime on POSIX key searching, adding and deleting operations. Memory overhead is lower than current implementation when the size of key and key value becomes big. |
