path: root/testsuites/psxtests/psxkey04 (follow)
* tests/psxtests: Use <rtems/test.h>Sebastian Huber2014-03-251-2/+6
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* POSIX keys now enabled in all configurations.Joel Sherrill2014-03-072-38/+48
| | | | | | | Formerly POSIX keys were only enabled when POSIX threads were enabled. Because they are a truly safe alternative to per-task variables in an SMP system, they are being enabled in all configurations.
* Unlimited objects support for POSIX keysZhongwei Yao2013-08-064-0/+184
This patch enables unlimited model in POSIX key manger and have a decent runtime on POSIX key searching, adding and deleting operations. Memory overhead is lower than current implementation when the size of key and key value becomes big.
