CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Formerly POSIX keys were only enabled when POSIX threads
were enabled. Because they are a truly safe alternative
to per-task variables in an SMP system, they are being
enabled in all configurations.
for details.
PR 1589/build
psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am,
psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am,
psxaio03/Makefile.am, psxalarm01/Makefile.am,
psxautoinit01/Makefile.am, psxautoinit02/Makefile.am,
psxbarrier01/Makefile.am, psxcancel/Makefile.am,
psxcancel01/Makefile.am, psxchroot01/Makefile.am,
psxclassic01/Makefile.am, psxcleanup/Makefile.am,
psxcleanup01/Makefile.am, psxclock/Makefile.am,
psxcond01/Makefile.am, psxeintr_join/Makefile.am,
psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am,
psxfile02/Makefile.am, psxfilelock01/Makefile.am,
psxgetrusage01/Makefile.am, psxid01/Makefile.am,
psximfs01/Makefile.am, psximfs02/Makefile.am,
psxintrcritical01/Makefile.am, psxitimer/Makefile.am,
psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am,
psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am,
psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxmutexattr01/Makefile.am, psxobj01/Makefile.am,
psxpasswd01/Makefile.am, psxpasswd02/Makefile.am,
psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am,
psxrwlock01/Makefile.am, psxsem01/Makefile.am,
psxsignal01/Makefile.am, psxsignal02/Makefile.am,
psxsignal03/Makefile.am, psxsignal04/Makefile.am,
psxsignal05/Makefile.am, psxsignal06/Makefile.am,
psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am,
psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am,
psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am,
psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am:
Remove obsolete optional manager capability.
PR 1867/cpukit
* Makefile.am, configure.ac, psx12/task.c, psxkey03/init.c,
psxrwlock01/test.c: Correct implementation of pthread_exit() and
pthread_join() to support the case where a thread is joinable but
calls pthread_exit() before a thread has attempted to join.
* psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c,
psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c,
psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c,
psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c,
psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c,
psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c,
psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c,
psxcancel01/init.c, psxchroot01/test.c, psxitimer/init.c,
psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c,
psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c,
psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c,
psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c,
psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c,
psxstack01/init.c, psxstack02/init.c, psxualarm/init.c: Eliminate
double space after parenthesis on rtems_test_assert().
psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am,
psxcleanup/Makefile.am, psxcleanup01/Makefile.am,
psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am,
psxfatal01/Makefile.am, psxfatal02/Makefile.am,
psxfile01/Makefile.am, psxintrcritical01/Makefile.am,
psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am,
psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxpasswd01/Makefile.am, psxrdwrv/Makefile.am,
psxreaddir/Makefile.am, psxrwlock01/Makefile.am,
psxsem01/Makefile.am, psxsignal01/Makefile.am,
psxsignal02/Makefile.am, psxsignal03/Makefile.am,
psxsignal04/Makefile.am, psxsignal05/Makefile.am,
psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am,
psxualarm/Makefile.am, psxusleep/Makefile.am: Revert accidentally
committed patch.
* Makefile.am, configure.ac, psx01/Makefile.am, psx02/Makefile.am,
psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am,
psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am,
psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am,
psxalarm01/Makefile.am, psxautoinit01/Makefile.am,
psxautoinit02/Makefile.am, psxbarrier01/Makefile.am,
psxcancel/Makefile.am, psxcancel01/Makefile.am,
psxchroot01/Makefile.am, psxcleanup/Makefile.am,
psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfile01/Makefile.am, psxfile02/init.c,
psxfile02/psxfile02.doc, psxfile02/psxfile02.scn,
psxualarm/Makefile.am, psxusleep/Makefile.am: Add test for fd greater
than number of file descriptors configured.
* include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c,
psx03/init.c, psx03/task.c, psx04/init.c, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c,
psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c,
psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c,
psxcancel01/init.c, psxchroot01/test.c, psxclock/init.c,
psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c,
psxfile01/test_write.c, psxitimer/init.c, psxkey01/task.c,
psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c,
psxmsgq03/init.c, psxmsgq04/init.c, psxreaddir/test.c,
psxstack01/init.c, psxstat/test.c, psxtime/test.c, psxualarm/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
PR 1466/tests
* Makefile.am, configure.ac, psxclock/init.c, psxclock/psxclock.doc,
psxclock/psxclock.scn, psxkey03/init.c, psxsignal02/init.c,
psxsignal03/init.c, psxstack01/init.c: Remove usleep() from tests.
Add test specifically to test it since it is deprecated as of
POSIX.1-2008.
* psxusleep/.cvsignore, psxusleep/Makefile.am, psxusleep/init.c,
psxusleep/psxusleep.doc, psxusleep/psxusleep.scn: New files.
Add missing prototypes.
* Makefile.am, configure.ac: Add new test to account for properly
handling keys when a thread has non-NULL key value and key has NULL
destructor and when a thread has NULL key value and key has
destructor.
* psxkey03/.cvsignore, psxkey03/Makefile.am, psxkey03/init.c,
psxkey03/psxkey03.doc, psxkey03/psxkey03.scn: New files.
