path: root/testsuites/psxtests/psxkey02 (unfollow)
2014-12-12posix: Delete key/value if value is set to NULLSebastian Huber1-0/+19
2014-04-07psxtests/psxkey02: Test for proper error caseSebastian Huber2-37/+14
2014-03-25tests/psxtests: Use <rtems/test.h>Sebastian Huber1-2/+6
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns2-2/+2
2014-03-07POSIX keys now enabled in all configurations.Joel Sherrill2-8/+8
Formerly POSIX keys were only enabled when POSIX threads were enabled. Because they are a truly safe alternative to per-task variables in an SMP system, they are being enabled in all configurations.
2013-06-25psxtests/psxkey02: SimplifySebastian Huber2-71/+23
This avoids problems with debugging enabled.
2012-05-11psxtests - Eliminate missing prototype warningsJoel Sherrill1-1/+4
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill3-9/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-05-07Revert: Remove CVS IdsJoel Sherrill1-0/+5
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details.
2012-05-04Remove CVS-Ids.Ralf Corsépius1-5/+0
2012-02-01Remove all .cvsignore files.Joel Sherrill1-2/+0
2011-12-082011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-3/+1
PR 1589/build * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am, psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am, psxaio03/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxclassic01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxeintr_join/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am, psxfile02/Makefile.am, psxfilelock01/Makefile.am, psxgetrusage01/Makefile.am, psxid01/Makefile.am, psximfs01/Makefile.am, psximfs02/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxsignal06/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Remove obsolete optional manager capability.
2011-02-22Add HAVE_CONFIG_H.Ralf Corsepius1-0/+4
2010-10-212010-10-21 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-13/+13
* psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c, psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c, psxcancel01/init.c, psxchroot01/test.c, psxitimer/init.c, psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c, psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c, psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c, psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c, psxstack01/init.c, psxstack02/init.c, psxualarm/init.c: Eliminate double space after parenthesis on rtems_test_assert().
2010-06-232010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill1-0/+1
* psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfile01/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Revert accidentally committed patch.
2010-06-232010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill1-1/+0
* Makefile.am, configure.ac, psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfile01/Makefile.am, psxfile02/init.c, psxfile02/psxfile02.doc, psxfile02/psxfile02.scn, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Add test for fd greater than number of file descriptors configured.
2009-12-082009-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-13/+13
* include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c, psx03/task.c, psx04/init.c, psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c, psxcancel01/init.c, psxchroot01/test.c, psxclock/init.c, psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c, psxfile01/test_write.c, psxitimer/init.c, psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c, psxreaddir/test.c, psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c, psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c, psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c, psxstack01/init.c, psxstat/test.c, psxtime/test.c, psxualarm/init.c: Use rtems_test_assert() consistently instead of system assert(). rtems_test_assert() is designed to integrate into the RTEMS test suite infrastructure.
2009-11-30Whitespace removal.Ralf Corsepius1-3/+3
2009-07-302009-07-30 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill5-0/+199
* Makefile.am, configure.ac: Add new test for exercising running out of memory while allocating the key pointers. * psxkey02/.cvsignore, psxkey02/Makefile.am, psxkey02/init.c, psxkey02/psxkey02.doc, psxkey02/psxkey02.scn: New files.
