* | libtest: <rtems/test.h> to <rtems/test-info.h> | Sebastian Huber | 2020-07-23 | 1 | -1/+1 |
| | | | | | | | | Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199. | ||||
* | Tests for inttype.h methods | Eshan dhawan | 2020-04-07 | 2 | -2/+32 |
* | libtest: Change expected pass state string | Sebastian Huber | 2019-12-05 | 1 | -1/+1 |
| | | | | Use separator character '_' for all test states. | ||||
* | psxinttypes01: Remove invalid test cases | Sebastian Huber | 2019-11-26 | 3 | -30/+6 |
| | | | | | | The functions expect a valid string as input according to POSIX. On systems with a NULL pointer protection the test cases ended up in exceptions. | ||||
* | psxtests: Add psxinttypes01 for <inttypes.h> methods | Vaibhav Gupta | 2019-06-19 | 3 | -0/+319 |
