path: root/testsuites/psxtests/psxinttypes01 (follow)
* libtest: <rtems/test.h> to <rtems/test-info.h>Sebastian Huber2020-07-231-1/+1
| | | | | | | | Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199.
* Tests for inttype.h methodsEshan dhawan2020-04-072-2/+32
* libtest: Change expected pass state stringSebastian Huber2019-12-051-1/+1
| | | | Use separator character '_' for all test states.
* psxinttypes01: Remove invalid test casesSebastian Huber2019-11-263-30/+6
| | | | | | The functions expect a valid string as input according to POSIX. On systems with a NULL pointer protection the test cases ended up in exceptions.
* psxtests: Add psxinttypes01 for <inttypes.h> methodsVaibhav Gupta2019-06-193-0/+319
