* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | psximfs02: Clean up output | Joel Sherrill | 2014-01-07 | 2 | -3/+4 |
* | score: Change greedy allocation API | Sebastian Huber | 2012-07-17 | 1 | -10/+15 |
* | psxtests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-11 | 1 | -2/+5 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+4 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -4/+0 |
* | Filesystem: Reference counting for locations | Sebastian Huber | 2012-03-13 | 1 | -17/+24 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | o A new data structure rtems_filesystem_global_location_t was introduced to be used for o the mount point location in the mount table entry, o the file system root location in the mount table entry, o the root directory location in the user environment, and o the current directory location in the user environment. During the path evaluation global start locations are obtained to ensure that the current file system instance will be not unmounted in the meantime. o The user environment uses now reference counting and is protected from concurrent access. o The path evaluation process was completely rewritten and simplified. The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation method. Recursive calls in the path evaluation have been replaced with iteration to avoid stack overflows. Only the evaluation of symbolic links is recursive. No dynamic memory allocations and intermediate buffers are used in the high level path evaluation. No global locks are held during the file system instance specific path evaluation process. o Recursive symbolic link evaluation is now limited by RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value via sysconf(). o The device file system (devFS) uses now no global variables and allocation from the workspace. Node names are allocated from the heap. o The upper layer lseek() performs now some parameter checks. o The upper layer ftruncate() performs now some parameter checks. o unmask() is now restricted to the RWX flags and protected from concurrent access. o The fchmod_h and rmnod_h file system node handlers are now a file system operation. o The unlink_h operation has been removed. All nodes are now destroyed with the rmnod_h operation. o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system operations. o The path evaluation and file system operations are now protected by per file system instance lock and unlock operations. o Fix and test file descriptor duplicate in fcntl(). o New test fstests/fsnofs01. | ||||
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am, psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am, psxaio03/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxclassic01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxeintr_join/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am, psxfile02/Makefile.am, psxfilelock01/Makefile.am, psxgetrusage01/Makefile.am, psxid01/Makefile.am, psximfs01/Makefile.am, psximfs02/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxsignal06/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Remove obsolete optional manager capability. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | 2011-02-14 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-02-14 | 1 | -0/+5 |
| | | | | | * psximfs02/init.c: Disable EPERM test which does not work when POSIX is disabled. | ||||
* | 2010-08-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-08-30 | 1 | -0/+4 |
| | | | | | | * configure.ac: AC_CHECK_DECLS([seteuid]). * psximfs02/init.c: Provide decl for seteuid if not provided by libc. | ||||
* | 2010-08-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-08-10 | 1 | -2/+1 |
| | | | | | PR 1665/testing * psximfs02/init.c: Fix uninitialized variable warning. | ||||
* | 2010-08-09 Bharath Suri <bharath.s.jois@gmail.com> | Joel Sherrill | 2010-08-09 | 1 | -0/+1 |
| | | | | | | | PR 1661/testing * psximfs02/init.c: Changes to improve coverage of imfs_initsupp.c, by using a bad value for CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK | ||||
* | 2010-08-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-08-09 | 1 | -5/+3 |
| | | | | | | PR 1661/testing * psxchroot01/test.c, psximfs01/init.c, psximfs02/init.c, psxpipe01/init.c: Eliminate most references to RTEMS_Malloc_Heap. | ||||
* | 2010-08-06 Bharath Suri <bharath.s.jois@gmail.com> | Joel Sherrill | 2010-08-07 | 2 | -2/+21 |
| | | | | | | | | | | | | | | PR 1654/testing * psx13/test.c, psx13/psx13.scn: Test case to improve testing of dup2 routine. * psxfile01/test.c, psxfile01/psxfile01.scn: New test to improve testing of fcntl routine. * psximfs01/init.c, psximfs01/psximfs01.scn: Improve testing of imfs routines. * psximfs02/init.c, psximfs02/psximfs02.scn: Improve coverage of imfs routines. * psxpasswd02/init.c, psxpasswd02/psxpasswd02.scn: New tests to improve coverage of getpwent.c. | ||||
* | 2010-07-30 Bharath Suri <bharath.s.jois@gmail.com> | Joel Sherrill | 2010-08-02 | 3 | -1/+58 |
| | | | | | | | PR 1642/testing * psximfs02/init.c, psximfs02/psximfs02.scn, psximfs02/psximfs02.doc: Added test cases to exercise chmod(), chown() and routines in imfs_debug.c. | ||||
* | 2010-07-29 Bharath Suri <bharath.s.jois@gmail.com> | Joel Sherrill | 2010-07-29 | 5 | -0/+244 |
PR 1642/testing * psximfs02/init.c, psximfs02/psximfs02.scn, psximfs02/psximfs02.doc, psximfs02/Makefile.am: New test added. * configure.ac, Makefile.am: Changes to accommodate psximfs02 test. |
