* psximfs02/init.c: Disable EPERM test which does not work when POSIX
is disabled.
* configure.ac: AC_CHECK_DECLS([seteuid]).
* psximfs02/init.c: Provide decl for seteuid if not provided by
libc.
PR 1665/testing
* psximfs02/init.c: Fix uninitialized variable warning.
PR 1661/testing
* psximfs02/init.c: Changes to improve coverage of
imfs_initsupp.c, by using a bad value for
CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
PR 1661/testing
* psxchroot01/test.c, psximfs01/init.c, psximfs02/init.c,
psxpipe01/init.c: Eliminate most references to RTEMS_Malloc_Heap.
PR 1654/testing
* psx13/test.c, psx13/psx13.scn: Test case to improve testing of
dup2 routine.
* psxfile01/test.c, psxfile01/psxfile01.scn: New test to improve
testing of fcntl routine.
* psximfs01/init.c, psximfs01/psximfs01.scn: Improve testing of
imfs routines.
* psximfs02/init.c, psximfs02/psximfs02.scn: Improve coverage of
imfs routines.
* psxpasswd02/init.c, psxpasswd02/psxpasswd02.scn: New tests to
improve coverage of getpwent.c.
PR 1642/testing
* psximfs02/init.c, psximfs02/psximfs02.scn,
psximfs02/psximfs02.doc: Added test cases to exercise chmod(),
chown() and routines in imfs_debug.c.
PR 1642/testing
psximfs02/psximfs02.doc, psximfs02/Makefile.am: New test added.
* configure.ac, Makefile.am: Changes to accommodate psximfs02
test.
