Updates #3053.
Update #3753.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
According to POSIX the lseek() function shall not, by itself, extend the
size of a file.
Remove the size field of rtems_libio_t. A file has only one size but
may have multiple open file descriptors. Thus a file size field in the
file descriptor may lead to inconsistencies.
New default handlers rtems_filesystem_default_lseek_file() and
rtems_filesystem_default_lseek_directory().
PR 1661/testing
* psxchroot01/test.c, psximfs01/init.c, psximfs02/init.c,
psxpipe01/init.c: Eliminate most references to RTEMS_Malloc_Heap.
PR 1654/testing
* psx13/test.c, psx13/psx13.scn: Test case to improve testing of
dup2 routine.
* psxfile01/test.c, psxfile01/psxfile01.scn: New test to improve
testing of fcntl routine.
* psximfs01/init.c, psximfs01/psximfs01.scn: Improve testing of
imfs routines.
* psximfs02/init.c, psximfs02/psximfs02.scn: Improve coverage of
imfs routines.
* psxpasswd02/init.c, psxpasswd02/psxpasswd02.scn: New tests to
improve coverage of getpwent.c.
PR 1633/testing
* psximfs01/init.c, psximfs01/psximfs01.scn,
psximfs01/psximfs01.doc: New cases to exercise
IMFS_memfile_remove.
* psximfs01/init.c: Fix warning introduced.
PR 1595/tests
* psximfs01/init.c: Fix warnings.
* Makefile.am, configure.ac: Add test to exercise IMFS behaviour with
files of maximum sizes.
* psximfs01/.cvsignore, psximfs01/Makefile.am, psximfs01/init.c,
psximfs01/psximfs01.doc, psximfs01/psximfs01.scn: New files.
