for details.
* psxhdrs/pthread01.c, psxhdrs/pthread02.c, psxhdrs/pthread03.c,
psxhdrs/pthread04.c, psxhdrs/pthread05.c, psxhdrs/pthread06.c,
psxhdrs/pthread07.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c,
psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c,
psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c,
psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c,
psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c,
psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c,
psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c,
psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread34.c,
psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/pthread37.c,
psxhdrs/pthread38.c, psxhdrs/pthread39.c, psxhdrs/pthread40.c:
Let test() return values (avoid warnings).
* psxhdrs/cond01.c, psxhdrs/cond02.c, psxhdrs/cond03.c,
psxhdrs/cond04.c, psxhdrs/cond05.c, psxhdrs/cond06.c,
psxhdrs/cond07.c, psxhdrs/cond08.c, psxhdrs/cond09.c,
psxhdrs/cond10.c: Let test() return values (avoid warnings).
* psxhdrs/mutex01.c, psxhdrs/mutex02.c, psxhdrs/mutex03.c,
psxhdrs/mutex04.c, psxhdrs/mutex05.c, psxhdrs/mutex06.c,
psxhdrs/mutex07.c, psxhdrs/mutex08.c, psxhdrs/mutex09.c,
psxhdrs/mutex10.c, psxhdrs/mutex11.c, psxhdrs/mutex12.c,
psxhdrs/mutex13.c, psxhdrs/mutex14.c, psxhdrs/mutex15.c,
psxhdrs/mutex16.c: Let test() return values (avoid warnings).
* psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c,
psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c,
psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c,
psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c,
psxhdrs/proc13.c, psxhdrs/proc14.c:
* psxhdrs/sched01.c, psxhdrs/sched02.c, psxhdrs/sched03.c,
psxhdrs/sched04.c, psxhdrs/sched05.c, psxhdrs/sched06.c,
psxhdrs/sched07.c, psxhdrs/sched08.c:
* psxhdrs/signal01.c, psxhdrs/signal02.c, psxhdrs/signal03.c,
psxhdrs/signal04.c, psxhdrs/signal05.c, psxhdrs/signal06.c,
psxhdrs/signal07.c, psxhdrs/signal08.c, psxhdrs/signal09.c,
psxhdrs/signal10.c, psxhdrs/signal11.c, psxhdrs/signal12.c,
psxhdrs/signal13.c, psxhdrs/signal14.c, psxhdrs/signal15.c,
psxhdrs/signal16.c, psxhdrs/signal17.c, psxhdrs/signal18.c,
psxhdrs/signal19.c, psxhdrs/signal20.c, psxhdrs/signal21.c,
psxhdrs/signal22.c, psxhdrs/signal23.c:
* psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c,
psxhdrs/key04.c: Let test() return values (avoid warnings).
* psxhdrs/clock01.c, psxhdrs/clock02.c, psxhdrs/clock03.c,
psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c:
* psxhdrs/signal23.c: Add comment to denote test as obsolete.
* psxhdrs/sync01.c, psxhdrs/sync02.c: Let test() return values
(avoid warnings).
* psxhdrs/time01.c, psxhdrs/time02.c, psxhdrs/time03.c,
psxhdrs/time04.c, psxhdrs/time05.c, psxhdrs/time06.c,
psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c,
psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c,
psxhdrs/time13.c: Let test() return values (avoid warnings).
* psxhdrs/timer01.c, psxhdrs/timer02.c, psxhdrs/timer03.c,
psxhdrs/timer04.c, psxhdrs/timer05.c, psxhdrs/timer06.c,
psxhdrs/timer07.c: Let test() return values (avoid warnings).
* psxhdrs/Makefile.am: Remove -Wno-unused-but-set-variable
(Non-portable).
* psx04/task3.c, psxfile01/test.c, psxhdrs/Makefile.am,
psxmsgq01/init.c, psxreaddir/test.c, psxsignal01/init.c,
psxtimes01/init.c, psxualarm/init.c: Remove warnings.
* psxhdrs/pthread37.c, psxhdrs/pthread38.c, psxhdrs/pthread39.c,
psxhdrs/pthread40.c: New files.
* Makefile.am, configure.ac, psx07/init.c, psx07/psx07.scn,
psxhdrs/Makefile.am, psxstack01/init.c: Add pthread_attr_getstack,
pthread_attr_setstack, pthread_attr_getguardsize, and
pthread_attr_setguardsize.
* psxstack02/.cvsignore, psxstack02/Makefile.am, psxstack02/init.c,
psxstack02/psxstack02.doc, psxstack02/psxstack02.scn: New files.
Add missing prototypes.
psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c,
psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c,
psxhdrs/key04.c, psxhdrs/mutex01.c, psxhdrs/mutex02.c,
psxhdrs/mutex03.c, psxhdrs/mutex04.c, psxhdrs/mutex05.c,
psxhdrs/mutex06.c, psxhdrs/mutex07.c, psxhdrs/mutex08.c,
psxhdrs/mutex09.c, psxhdrs/mutex10.c, psxhdrs/mutex11.c,
psxhdrs/mutex12.c, psxhdrs/mutex13.c, psxhdrs/mutex14.c,
psxhdrs/mutex15.c, psxhdrs/mutex16.c, psxhdrs/proc01.c,
psxhdrs/proc02.c, psxhdrs/proc03.c, psxhdrs/proc04.c,
psxhdrs/proc05.c, psxhdrs/proc06.c, psxhdrs/proc07.c,
psxhdrs/proc08.c, psxhdrs/proc09.c, psxhdrs/proc10.c,
psxhdrs/proc11.c, psxhdrs/proc12.c, psxhdrs/proc13.c,
psxhdrs/proc14.c, psxhdrs/pthread01.c, psxhdrs/pthread02.c,
psxhdrs/pthread03.c, psxhdrs/pthread04.c, psxhdrs/pthread05.c,
psxhdrs/pthread06.c, psxhdrs/pthread07.c, psxhdrs/pthread08.c,
psxhdrs/pthread09.c, psxhdrs/pthread10.c, psxhdrs/pthread11.c,
psxhdrs/pthread12.c, psxhdrs/pthread13.c, psxhdrs/pthread14.c,
psxhdrs/pthread15.c, psxhdrs/pthread16.c, psxhdrs/pthread17.c,
psxhdrs/pthread18.c, psxhdrs/pthread19.c, psxhdrs/pthread20.c,
psxhdrs/pthread21.c, psxhdrs/pthread22.c, psxhdrs/pthread23.c,
psxhdrs/pthread24.c, psxhdrs/pthread25.c, psxhdrs/pthread26.c,
psxhdrs/pthread27.c, psxhdrs/pthread28.c, psxhdrs/pthread29.c,
psxhdrs/pthread30.c, psxhdrs/pthread31.c, psxhdrs/pthread32.c,
psxhdrs/pthread33.c, psxhdrs/pthread34.c, psxhdrs/pthread35.c,
psxhdrs/pthread36.c, psxhdrs/sched01.c, psxhdrs/sched02.c,
psxhdrs/sched03.c, psxhdrs/sched04.c, psxhdrs/sched05.c,
psxhdrs/sched06.c, psxhdrs/sched07.c, psxhdrs/sched08.c,
psxhdrs/signal22.c, psxhdrs/signal23.c, psxhdrs/sync01.c,
psxhdrs/sync02.c, psxhdrs/sync03.c, psxhdrs/time01.c,
psxhdrs/time02.c, psxhdrs/time03.c, psxhdrs/time04.c,
psxhdrs/time05.c, psxhdrs/time06.c, psxhdrs/time07.c,
psxhdrs/time08.c, psxhdrs/time09.c, psxhdrs/time10.c,
psxhdrs/time11.c, psxhdrs/time12.c, psxhdrs/time13.c,
psxhdrs/timer07.c: Fix warnings.
* include/Makefile.am: Reformat.
* psx01/Makefile.am: Remove all-local: $(ARCH).
* psx02/Makefile.am: Remove all-local: $(ARCH).
* psx03/Makefile.am: Remove all-local: $(ARCH).
* psx04/Makefile.am: Remove all-local: $(ARCH).
* psx05/Makefile.am: Remove all-local: $(ARCH).
* psx06/Makefile.am: Remove all-local: $(ARCH).
* psx07/Makefile.am: Remove all-local: $(ARCH).
* psx08/Makefile.am: Remove all-local: $(ARCH).
* psx09/Makefile.am: Remove all-local: $(ARCH).
* psx10/Makefile.am: Remove all-local: $(ARCH).
* psx11/Makefile.am: Remove all-local: $(ARCH).
* psx12/Makefile.am: Remove all-local: $(ARCH).
* psx13/Makefile.am: Remove all-local: $(ARCH).
* psxcancel/Makefile.am: Remove all-local: $(ARCH).
* psxchroot01/Makefile.am: Remove all-local: $(ARCH).
* psxfile01/Makefile.am: Remove all-local: $(ARCH).
* psxhdrs/Makefile.am: Remove all-local: $(ARCH).
* psxmount/Makefile.am: Remove all-local: $(ARCH).
* psxmsgq01/Makefile.am: Remove all-local: $(ARCH).
* psxreaddir/Makefile.am: Remove all-local: $(ARCH).
* psxsem01/Makefile.am: Remove all-local: $(ARCH).
* psxstat/Makefile.am: Remove all-local: $(ARCH).
* psxtime/Makefile.am: Remove all-local: $(ARCH).
* psxtimer/Makefile.am: Remove all-local: $(ARCH).
* psxhdrs/sync01.c, psxhdrs/sync02.c: Correct fd creation
* psx01/init.c, psx01/system.h, psx01/task.c, psx02/init.c,
psx02/system.h, psx02/task.c, psx03/init.c, psx03/system.h,
psx03/task.c, psx04/init.c, psx04/system.h, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/system.h,
psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c,
psx06/system.h, psx06/task.c, psx06/task2.c, psx07/init.c,
psx07/system.h, psx07/task.c, psx08/init.c, psx08/system.h,
psx08/task1.c, psx08/task2.c, psx08/task3.c, psx09/init.c,
psx09/system.h, psx10/init.c, psx10/system.h, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/system.h,
psx11/task.c, psx12/init.c, psx12/system.h, psx12/task.c,
psx13/main.c, psx13/test.c, psxcancel/init.c, psxfile01/main.c,
psxfile01/test.c, psxhdrs/clock01.c, psxhdrs/clock02.c,
psxhdrs/clock03.c, psxhdrs/clock04.c, psxhdrs/clock05.c,
psxhdrs/clock06.c, psxhdrs/cond01.c, psxhdrs/cond02.c,
psxhdrs/cond03.c, psxhdrs/cond04.c, psxhdrs/cond05.c,
psxhdrs/cond06.c, psxhdrs/cond07.c, psxhdrs/cond08.c,
psxhdrs/cond09.c, psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c,
psxhdrs/key03.c, psxhdrs/key04.c, psxhdrs/mutex01.c,
psxhdrs/mutex02.c, psxhdrs/mutex03.c, psxhdrs/mutex04.c,
psxhdrs/mutex05.c, psxhdrs/mutex06.c, psxhdrs/mutex07.c,
psxhdrs/mutex08.c, psxhdrs/mutex09.c, psxhdrs/mutex10.c,
psxhdrs/mutex11.c, psxhdrs/mutex12.c, psxhdrs/mutex13.c,
psxhdrs/mutex14.c, psxhdrs/mutex15.c, psxhdrs/mutex16.c,
psxhdrs/proc13.c, psxhdrs/proc14.c, psxhdrs/pthread01.c,
psxhdrs/pthread02.c, psxhdrs/pthread03.c, psxhdrs/pthread04.c,
psxhdrs/pthread05.c, psxhdrs/pthread06.c, psxhdrs/pthread07.c,
psxhdrs/pthread08.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c,
psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread31.c,
psxhdrs/pthread32.c, psxhdrs/pthread33.c, psxhdrs/pthread34.c,
psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/sched01.c,
psxhdrs/sched02.c, psxhdrs/sched03.c, psxhdrs/sched04.c,
psxhdrs/sched05.c, psxhdrs/sched06.c, psxhdrs/sched07.c,
psxhdrs/sched08.c, psxhdrs/signal01.c, psxhdrs/signal02.c,
psxhdrs/signal03.c, psxhdrs/signal04.c, psxhdrs/signal05.c,
psxhdrs/signal06.c, psxhdrs/signal07.c, psxhdrs/signal08.c,
psxhdrs/signal09.c, psxhdrs/signal10.c, psxhdrs/signal11.c,
psxhdrs/signal12.c, psxhdrs/signal13.c, psxhdrs/signal14.c,
psxhdrs/signal15.c, psxhdrs/signal16.c, psxhdrs/signal17.c,
psxhdrs/signal18.c, psxhdrs/signal19.c, psxhdrs/signal20.c,
psxhdrs/signal21.c, psxhdrs/signal22.c, psxhdrs/signal23.c,
psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c,
psxhdrs/time13.c, psxhdrs/timer01.c, psxhdrs/timer02.c,
psxhdrs/timer03.c, psxhdrs/timer04.c, psxhdrs/timer05.c,
psxhdrs/timer06.c, psxhdrs/timer07.c, psxmsgq01/init.c,
psxmsgq01/system.h, psxsem01/system.h, psxstat/main.c,
psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c,
psxtimer/system.h: URL for license changed.
PR 462/tests
* psxhdrs/Makefile.am: Added ualarm.c
* psxhdrs/signal23.c: New file.
PR 463/tests
PR 465/tests
* psxhdrs/Makefile.am: Add new test cases.
* psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c,
psxhdrs/timer07.c: New files.
psx01/Makefile.am: Reflect having moved automake.
psx02/Makefile.am: Reflect having moved automake.
psx03/Makefile.am: Reflect having moved automake.
psx04/Makefile.am: Reflect having moved automake.
psx05/Makefile.am: Reflect having moved automake.
psx06/Makefile.am: Reflect having moved automake.
psx07/Makefile.am: Reflect having moved automake.
psx08/Makefile.am: Reflect having moved automake.
psx09/Makefile.am: Reflect having moved automake.
psx10/Makefile.am: Reflect having moved automake.
psx11/Makefile.am: Reflect having moved automake.
psx12/Makefile.am: Reflect having moved automake.
psx13/Makefile.am: Reflect having moved automake.
psxcancel/Makefile.am: Reflect having moved automake.
psxchroot01/Makefile.am: Reflect having moved automake.
psxfile01/Makefile.am: Reflect having moved automake.
psxhdrs/Makefile.am: Reflect having moved automake.
psxmount/Makefile.am: Reflect having moved automake.
psxmsgq01/Makefile.am: Reflect having moved automake.
psxreaddir/Makefile.am: Reflect having moved automake.
psxsem01/Makefile.am: Reflect having moved automake.
psxstat/Makefile.am: Reflect having moved automake.
psxtime/Makefile.am: Reflect having moved automake.
psxtimer/Makefile.am: Reflect having moved automake.
* psx02/init.c, psx04/init.c, psx13/test.c, psxchroot01/test.c,
psxhdrs/pthread07.c, psxmsgq01/init.c, psxreaddir/test.c,
psxtimer/psxtimer.c: Removed warnings.
* psx01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx02/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx03/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx04/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx05/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx06/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx07/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx08/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx09/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx10/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx11/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx12/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx13/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxcancel/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxchroot01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxfile01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxhdrs/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxmount/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxmsgq01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxreaddir/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxsem01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxstat/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxtime/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxtimer/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxcancel/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxchroot01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxfile01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxhdrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmount/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmsgq01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxreaddir/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxstat/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtime/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtimer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx11/Makefile.am: include leaf.am instead of leaf.cfg.
* psxcancel/Makefile.am: include leaf.am instead of leaf.cfg.
* psx02/Makefile.am: include leaf.am instead of leaf.cfg.
* psx13/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtime/Makefile.am: include leaf.am instead of leaf.cfg.
* psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx07/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtimer/Makefile.am: include leaf.am instead of leaf.cfg.
* psx10/Makefile.am: include leaf.am instead of leaf.cfg.
* psx08/Makefile.am: include leaf.am instead of leaf.cfg.
* psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg.
* psxfile01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx05/Makefile.am: include leaf.am instead of leaf.cfg.
* psx09/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmount/Makefile.am: include leaf.am instead of leaf.cfg.
* psxstat/Makefile.am: include leaf.am instead of leaf.cfg.
* psx12/Makefile.am: include leaf.am instead of leaf.cfg.
* psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg.
* psxsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx03/Makefile.am: include leaf.am instead of leaf.cfg.
* psx04/Makefile.am: include leaf.am instead of leaf.cfg.
* psx06/Makefile.am: include leaf.am instead of leaf.cfg.
psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am,
psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am,
psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am
