updates #2732
The dummy for setgroups() allows applications using it to build (for example
civetweb webserver).
This is the very simple implementation specified by the Open Group
for implementations with 1:1 kernel thread to user thread mappings.
http://pubs.opengroup.org/onlinepubs/9699919799/functions/pthread_getconcurrency.html
updates #2680.
Fix link-time errors introduced by
e39cdb875ce7458787b0be173f2f7893a774a673.
Update #2531.
This is a better organization and makes it clearer which file
is testing which method from which header file.
These methods are no longer in the tree and the API tests should
have been removed.
closes 1981
The pthread_cleanup_push() and pthread_cleanup_pop() statements must
appear as a pair in the same lexical scope as required by POSIX.
for details.
* psxhdrs/pthread01.c, psxhdrs/pthread02.c, psxhdrs/pthread03.c,
psxhdrs/pthread04.c, psxhdrs/pthread05.c, psxhdrs/pthread06.c,
psxhdrs/pthread07.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c,
psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c,
psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c,
psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c,
psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c,
psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c,
psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c,
psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread34.c,
psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/pthread37.c,
psxhdrs/pthread38.c, psxhdrs/pthread39.c, psxhdrs/pthread40.c:
Let test() return values (avoid warnings).
* psxhdrs/cond01.c, psxhdrs/cond02.c, psxhdrs/cond03.c,
psxhdrs/cond04.c, psxhdrs/cond05.c, psxhdrs/cond06.c,
psxhdrs/cond07.c, psxhdrs/cond08.c, psxhdrs/cond09.c,
psxhdrs/cond10.c: Let test() return values (avoid warnings).
* psxhdrs/mutex01.c, psxhdrs/mutex02.c, psxhdrs/mutex03.c,
psxhdrs/mutex04.c, psxhdrs/mutex05.c, psxhdrs/mutex06.c,
psxhdrs/mutex07.c, psxhdrs/mutex08.c, psxhdrs/mutex09.c,
psxhdrs/mutex10.c, psxhdrs/mutex11.c, psxhdrs/mutex12.c,
psxhdrs/mutex13.c, psxhdrs/mutex14.c, psxhdrs/mutex15.c,
psxhdrs/mutex16.c: Let test() return values (avoid warnings).
* psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c,
psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c,
psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c,
psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c,
psxhdrs/proc13.c, psxhdrs/proc14.c:
* psxhdrs/sched01.c, psxhdrs/sched02.c, psxhdrs/sched03.c,
psxhdrs/sched04.c, psxhdrs/sched05.c, psxhdrs/sched06.c,
psxhdrs/sched07.c, psxhdrs/sched08.c:
* psxhdrs/signal01.c, psxhdrs/signal02.c, psxhdrs/signal03.c,
psxhdrs/signal04.c, psxhdrs/signal05.c, psxhdrs/signal06.c,
psxhdrs/signal07.c, psxhdrs/signal08.c, psxhdrs/signal09.c,
psxhdrs/signal10.c, psxhdrs/signal11.c, psxhdrs/signal12.c,
psxhdrs/signal13.c, psxhdrs/signal14.c, psxhdrs/signal15.c,
psxhdrs/signal16.c, psxhdrs/signal17.c, psxhdrs/signal18.c,
psxhdrs/signal19.c, psxhdrs/signal20.c, psxhdrs/signal21.c,
psxhdrs/signal22.c, psxhdrs/signal23.c:
* psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c,
psxhdrs/key04.c: Let test() return values (avoid warnings).
* psxhdrs/clock01.c, psxhdrs/clock02.c, psxhdrs/clock03.c,
psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c:
* psxhdrs/signal23.c: Add comment to denote test as obsolete.
* psxhdrs/sync01.c, psxhdrs/sync02.c: Let test() return values
(avoid warnings).
* psxhdrs/time01.c, psxhdrs/time02.c, psxhdrs/time03.c,
psxhdrs/time04.c, psxhdrs/time05.c, psxhdrs/time06.c,
psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c,
psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c,
psxhdrs/time13.c: Let test() return values (avoid warnings).
* psxhdrs/timer01.c, psxhdrs/timer02.c, psxhdrs/timer03.c,
psxhdrs/timer04.c, psxhdrs/timer05.c, psxhdrs/timer06.c,
psxhdrs/timer07.c: Let test() return values (avoid warnings).
* psxhdrs/Makefile.am: Remove -Wno-unused-but-set-variable
(Non-portable).
* psx04/task3.c, psxfile01/test.c, psxhdrs/Makefile.am,
psxmsgq01/init.c, psxreaddir/test.c, psxsignal01/init.c,
psxtimes01/init.c, psxualarm/init.c: Remove warnings.
* psxhdrs/pthread37.c, psxhdrs/pthread38.c, psxhdrs/pthread39.c,
psxhdrs/pthread40.c: New files.
* Makefile.am, configure.ac, psx07/init.c, psx07/psx07.scn,
psxhdrs/Makefile.am, psxstack01/init.c: Add pthread_attr_getstack,
pthread_attr_setstack, pthread_attr_getguardsize, and
pthread_attr_setguardsize.
* psxstack02/.cvsignore, psxstack02/Makefile.am, psxstack02/init.c,
psxstack02/psxstack02.doc, psxstack02/psxstack02.scn: New files.
Add missing prototypes.
psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c,
psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c,
psxhdrs/key04.c, psxhdrs/mutex01.c, psxhdrs/mutex02.c,
psxhdrs/mutex03.c, psxhdrs/mutex04.c, psxhdrs/mutex05.c,
psxhdrs/mutex06.c, psxhdrs/mutex07.c, psxhdrs/mutex08.c,
psxhdrs/mutex09.c, psxhdrs/mutex10.c, psxhdrs/mutex11.c,
psxhdrs/mutex12.c, psxhdrs/mutex13.c, psxhdrs/mutex14.c,
psxhdrs/mutex15.c, psxhdrs/mutex16.c, psxhdrs/proc01.c,
psxhdrs/proc02.c, psxhdrs/proc03.c, psxhdrs/proc04.c,
psxhdrs/proc05.c, psxhdrs/proc06.c, psxhdrs/proc07.c,
psxhdrs/proc08.c, psxhdrs/proc09.c, psxhdrs/proc10.c,
psxhdrs/proc11.c, psxhdrs/proc12.c, psxhdrs/proc13.c,
psxhdrs/proc14.c, psxhdrs/pthread01.c, psxhdrs/pthread02.c,
psxhdrs/pthread03.c, psxhdrs/pthread04.c, psxhdrs/pthread05.c,
psxhdrs/pthread06.c, psxhdrs/pthread07.c, psxhdrs/pthread08.c,
psxhdrs/pthread09.c, psxhdrs/pthread10.c, psxhdrs/pthread11.c,
psxhdrs/pthread12.c, psxhdrs/pthread13.c, psxhdrs/pthread14.c,
psxhdrs/pthread15.c, psxhdrs/pthread16.c, psxhdrs/pthread17.c,
psxhdrs/pthread18.c, psxhdrs/pthread19.c, psxhdrs/pthread20.c,
psxhdrs/pthread21.c, psxhdrs/pthread22.c, psxhdrs/pthread23.c,
psxhdrs/pthread24.c, psxhdrs/pthread25.c, psxhdrs/pthread26.c,
psxhdrs/pthread27.c, psxhdrs/pthread28.c, psxhdrs/pthread29.c,
psxhdrs/pthread30.c, psxhdrs/pthread31.c, psxhdrs/pthread32.c,
psxhdrs/pthread33.c, psxhdrs/pthread34.c, psxhdrs/pthread35.c,
psxhdrs/pthread36.c, psxhdrs/sched01.c, psxhdrs/sched02.c,
psxhdrs/sched03.c, psxhdrs/sched04.c, psxhdrs/sched05.c,
psxhdrs/sched06.c, psxhdrs/sched07.c, psxhdrs/sched08.c,
psxhdrs/signal22.c, psxhdrs/signal23.c, psxhdrs/sync01.c,
psxhdrs/sync02.c, psxhdrs/sync03.c, psxhdrs/time01.c,
psxhdrs/time02.c, psxhdrs/time03.c, psxhdrs/time04.c,
psxhdrs/time05.c, psxhdrs/time06.c, psxhdrs/time07.c,
psxhdrs/time08.c, psxhdrs/time09.c, psxhdrs/time10.c,
psxhdrs/time11.c, psxhdrs/time12.c, psxhdrs/time13.c,
psxhdrs/timer07.c: Fix warnings.
* include/Makefile.am: Reformat.
* psx01/Makefile.am: Remove all-local: $(ARCH).
* psx02/Makefile.am: Remove all-local: $(ARCH).
* psx03/Makefile.am: Remove all-local: $(ARCH).
* psx04/Makefile.am: Remove all-local: $(ARCH).
* psx05/Makefile.am: Remove all-local: $(ARCH).
* psx06/Makefile.am: Remove all-local: $(ARCH).
* psx07/Makefile.am: Remove all-local: $(ARCH).
* psx08/Makefile.am: Remove all-local: $(ARCH).
* psx09/Makefile.am: Remove all-local: $(ARCH).
* psx10/Makefile.am: Remove all-local: $(ARCH).
* psx11/Makefile.am: Remove all-local: $(ARCH).
* psx12/Makefile.am: Remove all-local: $(ARCH).
* psx13/Makefile.am: Remove all-local: $(ARCH).
* psxcancel/Makefile.am: Remove all-local: $(ARCH).
* psxchroot01/Makefile.am: Remove all-local: $(ARCH).
* psxfile01/Makefile.am: Remove all-local: $(ARCH).
* psxhdrs/Makefile.am: Remove all-local: $(ARCH).
* psxmount/Makefile.am: Remove all-local: $(ARCH).
* psxmsgq01/Makefile.am: Remove all-local: $(ARCH).
* psxreaddir/Makefile.am: Remove all-local: $(ARCH).
* psxsem01/Makefile.am: Remove all-local: $(ARCH).
* psxstat/Makefile.am: Remove all-local: $(ARCH).
* psxtime/Makefile.am: Remove all-local: $(ARCH).
* psxtimer/Makefile.am: Remove all-local: $(ARCH).
* psxhdrs/sync01.c, psxhdrs/sync02.c: Correct fd creation
* psx01/init.c, psx01/system.h, psx01/task.c, psx02/init.c,
psx02/system.h, psx02/task.c, psx03/init.c, psx03/system.h,
psx03/task.c, psx04/init.c, psx04/system.h, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/system.h,
psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c,
psx06/system.h, psx06/task.c, psx06/task2.c, psx07/init.c,
psx07/system.h, psx07/task.c, psx08/init.c, psx08/system.h,
psx08/task1.c, psx08/task2.c, psx08/task3.c, psx09/init.c,
psx09/system.h, psx10/init.c, psx10/system.h, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/system.h,
psx11/task.c, psx12/init.c, psx12/system.h, psx12/task.c,
psx13/main.c, psx13/test.c, psxcancel/init.c, psxfile01/main.c,
psxfile01/test.c, psxhdrs/clock01.c, psxhdrs/clock02.c,
psxhdrs/clock03.c, psxhdrs/clock04.c, psxhdrs/clock05.c,
psxhdrs/clock06.c, psxhdrs/cond01.c, psxhdrs/cond02.c,
psxhdrs/cond03.c, psxhdrs/cond04.c, psxhdrs/cond05.c,
psxhdrs/cond06.c, psxhdrs/cond07.c, psxhdrs/cond08.c,
psxhdrs/cond09.c, psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c,
psxhdrs/key03.c, psxhdrs/key04.c, psxhdrs/mutex01.c,
psxhdrs/mutex02.c, psxhdrs/mutex03.c, psxhdrs/mutex04.c,
psxhdrs/mutex05.c, psxhdrs/mutex06.c, psxhdrs/mutex07.c,
psxhdrs/mutex08.c, psxhdrs/mutex09.c, psxhdrs/mutex10.c,
psxhdrs/mutex11.c, psxhdrs/mutex12.c, psxhdrs/mutex13.c,
psxhdrs/mutex14.c, psxhdrs/mutex15.c, psxhdrs/mutex16.c,
psxhdrs/proc13.c, psxhdrs/proc14.c, psxhdrs/pthread01.c,
psxhdrs/pthread02.c, psxhdrs/pthread03.c, psxhdrs/pthread04.c,
psxhdrs/pthread05.c, psxhdrs/pthread06.c, psxhdrs/pthread07.c,
psxhdrs/pthread08.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c,
psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread31.c,
psxhdrs/pthread32.c, psxhdrs/pthread33.c, psxhdrs/pthread34.c,
psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/sched01.c,
psxhdrs/sched02.c, psxhdrs/sched03.c, psxhdrs/sched04.c,
psxhdrs/sched05.c, psxhdrs/sched06.c, psxhdrs/sched07.c,
psxhdrs/sched08.c, psxhdrs/signal01.c, psxhdrs/signal02.c,
psxhdrs/signal03.c, psxhdrs/signal04.c, psxhdrs/signal05.c,
psxhdrs/signal06.c, psxhdrs/signal07.c, psxhdrs/signal08.c,
psxhdrs/signal09.c, psxhdrs/signal10.c, psxhdrs/signal11.c,
psxhdrs/signal12.c, psxhdrs/signal13.c, psxhdrs/signal14.c,
psxhdrs/signal15.c, psxhdrs/signal16.c, psxhdrs/signal17.c,
psxhdrs/signal18.c, psxhdrs/signal19.c, psxhdrs/signal20.c,
psxhdrs/signal21.c, psxhdrs/signal22.c, psxhdrs/signal23.c,
psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c,
psxhdrs/time13.c, psxhdrs/timer01.c, psxhdrs/timer02.c,
psxhdrs/timer03.c, psxhdrs/timer04.c, psxhdrs/timer05.c,
psxhdrs/timer06.c, psxhdrs/timer07.c, psxmsgq01/init.c,
psxmsgq01/system.h, psxsem01/system.h, psxstat/main.c,
psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c,
psxtimer/system.h: URL for license changed.
PR 462/tests
* psxhdrs/Makefile.am: Added ualarm.c
* psxhdrs/signal23.c: New file.
PR 463/tests
PR 465/tests
* psxhdrs/Makefile.am: Add new test cases.
* psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c,
psxhdrs/timer07.c: New files.
