* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 135 | -270/+270 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 135 | -675/+675 |
* | initialized variables or removed unused variables to remove warnings | Joel Sherrill | 1997-04-02 | 3 | -4/+3 |
* | changed phrase "RTEMS is support" to "RTEMS is supposed" | Joel Sherrill | 1996-08-08 | 12 | -12/+12 |
* | new file | Joel Sherrill | 1996-05-24 | 14 | -0/+337 |
* | added use of sporadic server scheduling parameters | Joel Sherrill | 1996-05-24 | 7 | -0/+58 |
* | new files | Joel Sherrill | 1996-05-24 | 3 | -0/+96 |
* | clean up on DELAYTIMER_MAX | Joel Sherrill | 1996-05-23 | 3 | -12/+0 |
* | new files | Joel Sherrill | 1996-05-23 | 6 | -0/+204 |
* | unused variable | Joel Sherrill | 1996-05-23 | 1 | -1/+0 |
* | new files | Joel Sherrill | 1996-05-23 | 8 | -0/+208 |
* | new files | Joel Sherrill | 1996-05-23 | 7 | -0/+184 |
* | new files | Joel Sherrill | 1996-05-23 | 3 | -0/+75 |
* | new files | Joel Sherrill | 1996-05-23 | 5 | -0/+144 |
* | new files | Joel Sherrill | 1996-05-23 | 4 | -0/+110 |
* | cleanup | Joel Sherrill | 1996-05-23 | 8 | -12/+12 |
* | new files | Joel Sherrill | 1996-05-23 | 8 | -0/+254 |
* | cleanup status vs. result | Joel Sherrill | 1996-05-23 | 29 | -48/+48 |
* | new files | Joel Sherrill | 1996-05-23 | 5 | -0/+152 |
* | new files | Joel Sherrill | 1996-05-23 | 4 | -0/+134 |
* | new files | Joel Sherrill | 1996-05-23 | 2 | -0/+60 |
* | new files | Joel Sherrill | 1996-05-23 | 6 | -0/+200 |
* | new files | Joel Sherrill | 1996-05-23 | 9 | -0/+288 |
* | updated to reflect more constants and feature macros | Joel Sherrill | 1996-05-23 | 34 | -5/+160 |
* | created posix test suite with test of header files | Joel Sherrill | 1996-05-22 | 51 | -0/+1379 |
