* | psxtests: Fix math function build warnings | Stephen Clark | 2021-05-05 | 60 | -0/+231 |
| | | | | | Added conditionals to ensure that long double function tests were only built when newlib has long double math functions. | ||||
* | psxhdrs/strncpy/stpncpy: Fix string turncation warning | Aschref Ben Thabet | 2020-08-05 | 2 | -8/+6 |
| | | | | | | Since we need to test the strncpy function, using a character array with a fixed array size in this case in place of character pointer can avoid the string turncation warning. | ||||
* | psxhdrs/strncat: Fix string truncation warning | Aschref Ben Thabet | 2020-07-30 | 1 | -1/+1 |
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 60 | -60/+60 |
* | Move feature macro before "config.h" include | Sebastian Huber | 2019-12-02 | 22 | -35/+56 |
| | | | | | | | This allows to use header includes in "config.h" to reduce the build configuration checks. Update #3818. | ||||
* | psxhdrs: Add POSIX API Signature Compliance Tests for termios.h | Jacob Shin | 2019-05-07 | 11 | -0/+549 |
* | psxhdrs/stdio/v*.c: Fix warnings in varargs tests | Joel Sherrill | 2019-03-25 | 8 | -16/+26 |
* | psxtests: Remove bogus file | Sebastian Huber | 2019-02-12 | 1 | -38/+0 |
| | | | | | | This file is unused and makes trouble on Windows. Updates #3638. | ||||
* | psxhdrs: Add POSIX API Signature Compliance Tests for errno.h | Jacob Shin | 2019-01-08 | 1 | -0/+44 |
* | psxhdrs: Changing copyright license to BSD-2-Clause | Jacob Shin | 2018-12-20 | 139 | -1535/+3062 |
* | psxhdrs: Update licenses to 2-Clause BSD (GCI 2018) | Marçal Comajoan Cara | 2018-12-14 | 12 | -132/+264 |
| | | | | | | Updated licenses of the files I wrote to the 2-Clause BSD License. This work was part of GCI 2018. | ||||
* | Some minor fix on psxhdrs | Himanshu40 | 2018-12-14 | 4 | -18/+4 |
* | psxhdrs: Changed the copyright license to BSD-2-Clause (GCI 2018) | Himanshu40 | 2018-12-14 | 218 | -2663/+5067 |
* | psxhdrs: Changed the Copyright license to BSD-2-Clause . | Pritish Jain | 2018-12-13 | 195 | -2935/+5080 |
| | | | | | The Copyright clause has been changed to BSD-2-Clause for all the tests in the header files math.h , utime.h , fmtmsg.h and sys/ipc.h . | ||||
* | psxhdrs: Add POSIX API Signature Compliance Tests for sys/msg.h (GCI 2018) | Jacob Shin | 2018-12-13 | 4 | -0/+215 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for sys/select.h (GCI 2018) | Jacob Shin | 2018-12-13 | 6 | -0/+297 |
| | | | | The Google Code-In finished before I could submit this, so I thought I would submit this instead of letting it go to waste. | ||||
* | psxhdrs: Add POSIX Signature Compliance Test for sys/shm.h (GCI 2018) | ABR290B | 2018-12-13 | 4 | -0/+147 |
* | POSIX Signature Compliance Test for utmpx.h (GCI2018) | ABR290B | 2018-12-13 | 6 | -0/+212 |
* | POSIX Signature Compliance Test for sys/statvfs.h (GCI 2018) | ABR290B | 2018-12-13 | 2 | -0/+74 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for net/if.h | Jacob Shin | 2018-12-12 | 4 | -0/+191 |
* | psxhdrs/: Changed boilerplate licenses to BSD-2 (GCI 2018) | zehata | 2018-12-11 | 187 | -2149/+4205 |
* | psxhdrs: POSIX API Signature Compliance Test for setjmp.h (GCI2018) | ABR290B | 2018-12-11 | 4 | -0/+141 |
* | psxhdrs: Implement POSIX API Signature Compliance Tests for poll.h (GCI 2018) | Marçal Comajoan Cara | 2018-12-11 | 1 | -0/+50 |
| | | | | | | | poll.h implements poll() which is not supported by RTEMS according to the RTEMS POSIX 1003.1 Compliance Guide. See #3657. This work was part of GCI 2018. | ||||
* | psxhdrs: Add POSIX Compliance Tests for wordexp.h (GCI 2018) | Pritish Jain | 2018-12-11 | 2 | -0/+99 |
* | psxhdrs: Fix compile errors | Sebastian Huber | 2018-12-11 | 8 | -16/+16 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for pwd.h (GCI 2018) | Himanshu40 | 2018-12-10 | 7 | -0/+288 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for fcntl.h (GCI 2018) | Zenon | 2018-12-10 | 4 | -0/+151 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for sys/resource.h (GCI 2018) | Jacob Shin | 2018-12-10 | 5 | -0/+196 |
* | psxhdrs: Implement POSIX API Signature Compliance Tests for sys/times.h (GCI ↵ | Marçal Comajoan Cara | 2018-12-09 | 1 | -0/+37 |
| | | | | 2018) | ||||
* | psxhdrs: Add POSIX Conformance Test for sys/ipc.h (GCI 2018) | Shashvat Jain | 2018-12-09 | 1 | -0/+40 |
| | | | | | | | Test for this file has been added but are disabled due to the absence of header file sys/ipc.h. see Ticket #3650 | ||||
* | psxhdrs: Add POSIX API Signature Compliance Tests for sys/stat.h (GCI 2018) | Jacob Shin | 2018-12-09 | 16 | -0/+622 |
* | psxhdrs: Added POSIX API Signature Compliance Tests for threads.h (GCI 2018) | Himanshu40 | 2018-12-09 | 25 | -0/+1044 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for stdlib.h (GCI 2018) | Jacob Shin | 2018-12-09 | 65 | -0/+2398 |
* | psxhdrs: POSIX Signature Test for syslog.h (GCI2018) | ABR290B | 2018-12-08 | 4 | -0/+136 |
* | psxhdrs: added POSIX API Signature Compliance Tests for libgen.h (GCI 2018) | Himanshu40 | 2018-12-08 | 2 | -0/+76 |
* | psxhdrs: Added POSIX Compliance Test for wchar.h (GCI 2018) | zehata | 2018-12-08 | 82 | -0/+3190 |
* | Implement POSIX API Signature Compliance Tests for stddef.h (GCI 2018) | Marçal Comajoan Cara | 2018-12-08 | 1 | -0/+38 |
* | POSIX Signature Test for arpa/inet.h (GCI2018) | ABR290B | 2018-12-08 | 4 | -0/+156 |
* | psxhdrs: POSIX API Signature Compliance Tests for netdb.h (GCI 2018) | Himanshu40 | 2018-12-07 | 25 | -0/+1001 |
* | Implement POSIX API Signature Compliance Tests for uchar.h | Marçal Comajoan Cara | 2018-12-07 | 4 | -0/+164 |
| | | | | | | | This header file is C11 and not currently supported by RTEMS. See #3643. This work was part of GCI 2018. | ||||
* | psxhdrs: Add POSIX API Signature Compliance Tests for ucontext.h (GCI 2018) | Jacob Shin | 2018-12-06 | 4 | -0/+192 |
* | Implement POSIX API Signature Compliance Tests for inttypes.h | Marçal Comajoan Cara | 2018-12-06 | 6 | -0/+235 |
| | | | | This work was part of GCI 2018 | ||||
* | psxhdrs:Add POSIX Conformance Test for fmtmsg.h (GCI 2018) | Shashvat Jain | 2018-12-06 | 1 | -17/+24 |
* | psxhdrs:Add POSIX Conformance Test for fmtmsg.h (GCI 2018) | Shashvat Jain | 2018-12-06 | 1 | -0/+39 |
| | | | | | | | Includes test fmtmsg which has been disabled due to the absence of header file fmtmsg.h . Updates #3639 | ||||
* | psxhdrs: Add POSIX API Signature Compliance Tests for string.h (GCI 2018) | Himanshu40 | 2018-12-06 | 34 | -0/+1332 |
* | Added POSIX Compliance Test for <ctype.h> (GCI 2018) | zehata | 2018-12-06 | 30 | -0/+1096 |
* | psxhdrs: Add POSIX Conformance Tests for math.h (GCI 2018) | Shashvat Jain | 2018-12-06 | 193 | -0/+7305 |
| | | | | | | | | | Includes API tests for y0l, y1l, and ynl which are in glibc but not in POSIX or newlib. They are disabled until further investigation as to compatibility requirements are determined per the referenced ticket. Updates #3638. | ||||
* | POSIX Signature Test for fenv.h (GCI 2018) | ABR290B | 2018-12-06 | 11 | -0/+375 |
| | | | | Updates #2971. | ||||
* | psxhdrs: Add POSIX API Signature Compliance Tests for wctype.h (GCI 2018) | Jacob Shin | 2018-12-06 | 36 | -0/+1341 |
* | POSIX Compliance Signature Test for glob.h (GCI 2018) | ABR290B | 2018-12-05 | 2 | -0/+79 |
