2022-06-21 | testsuite: Fix gcc 12 warnings | Chris Johns | 11 | -20/+20 | |
2022-04-12 | testsuites/psxtests/psxhdrs/sys/socket/*: Change license to BSD-2 | Joel Sherrill | 17 | -51/+374 | |
Updates #3053. | |||||
2022-04-12 | testsuites/psxtests/psxhdrs/sys/mman/*: Change license to BSD-2 | Joel Sherrill | 11 | -33/+242 | |
2021-08-09 | Turn off executable permissions for a number of source files | Joel Sherrill | 11 | -0/+0 | |
Cloning under Cygwin turned off executable permission on these files. This shows them as modified even though they have not explicitly been touched. Executable permission should not have been on for these files so this is just a minor clean up. | |||||
2019-12-02 | Move feature macro before "config.h" include | Sebastian Huber | 2 | -3/+5 | |
This allows to use header includes in "config.h" to reduce the build configuration checks. Update #3818. | |||||
2018-12-20 | psxhdrs: Changing copyright license to BSD-2-Clause | Jacob Shin | 22 | -246/+488 | |
2018-12-14 | psxhdrs: Update licenses to 2-Clause BSD (GCI 2018) | Marçal Comajoan Cara | 1 | -11/+22 | |
Updated licenses of the files I wrote to the 2-Clause BSD License. This work was part of GCI 2018. | |||||
2018-12-13 | psxhdrs: Changed the Copyright license to BSD-2-Clause . | Pritish Jain | 1 | -13/+24 | |
The Copyright clause has been changed to BSD-2-Clause for all the tests in the header files math.h , utime.h , fmtmsg.h and sys/ipc.h . | |||||
2018-12-13 | psxhdrs: Add POSIX API Signature Compliance Tests for sys/msg.h (GCI 2018) | Jacob Shin | 4 | -0/+215 | |
2018-12-13 | psxhdrs: Add POSIX API Signature Compliance Tests for sys/select.h (GCI 2018) | Jacob Shin | 6 | -0/+297 | |
The Google Code-In finished before I could submit this, so I thought I would submit this instead of letting it go to waste. | |||||
2018-12-13 | psxhdrs: Add POSIX Signature Compliance Test for sys/shm.h (GCI 2018) | ABR290B | 4 | -0/+147 | |
2018-12-13 | POSIX Signature Compliance Test for sys/statvfs.h (GCI 2018) | ABR290B | 2 | -0/+74 | |
2018-12-11 | psxhdrs/: Changed boilerplate licenses to BSD-2 (GCI 2018) | zehata | 5 | -60/+115 | |
2018-12-10 | psxhdrs: Add POSIX API Signature Compliance Tests for sys/resource.h (GCI 2018) | Jacob Shin | 5 | -0/+196 | |
2018-12-09 | psxhdrs: Implement POSIX API Signature Compliance Tests for sys/times.h (GCI ↵ | Marçal Comajoan Cara | 1 | -0/+37 | |
2018) | |||||
2018-12-09 | psxhdrs: Add POSIX Conformance Test for sys/ipc.h (GCI 2018) | Shashvat Jain | 1 | -0/+40 | |
Test for this file has been added but are disabled due to the absence of header file sys/ipc.h. see Ticket #3650 | |||||
2018-12-09 | psxhdrs: Add POSIX API Signature Compliance Tests for sys/stat.h (GCI 2018) | Jacob Shin | 16 | -0/+622 | |
2018-12-05 | psxhdrs: POSIX API Signature Compliance Tests for sys/utsname.h (GCI 2018) | Jacob Shin | 1 | -0/+37 | |
2018-12-04 | psxhdrs: Fix warnings | Joel Sherrill | 3 | -19/+10 | |
2018-12-04 | psxhdrs: Added POSIX Compliance Test fot sys/time.h (GCI 2018) | zehata | 5 | -0/+207 | |
2018-11-14 | testsuites/psxtests/psxhdrs: Fix comment so copyright block is separate | Joel Sherrill | 11 | -55/+55 | |
2017-01-13 | posix: move sys/mman.h to newlib and test it in psxhdrs | Gedare Bloom | 11 | -0/+309 | |
2015-02-12 | psxhdrs: Add tests for <sys/socket.h> API compliance | Joel Sherrill | 17 | -0/+595 | |
