path: root/testsuites/psxtests/psxgetrusage01 (unfollow)
2014-03-25tests/psxtests: Use <rtems/test.h>Sebastian Huber1-2/+6
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns2-2/+2
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill3-9/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-05-07Revert: Remove CVS IdsJoel Sherrill1-0/+5
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details.
2012-05-04Remove CVS-Ids.Ralf Corsépius1-5/+0
2012-02-01Remove all .cvsignore files.Joel Sherrill1-2/+0
2011-12-132011-12-13 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-17/+18
* configure.ac: Check for getrusage decl. * psxgetrusage01/init.c: Fix header file inclusion order. Move configuration section up. Apply HAVE_DECL_GETRUSAGE.
2011-12-082011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-2/+1
PR 1589/build * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am, psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am, psxaio03/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxclassic01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxeintr_join/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am, psxfile02/Makefile.am, psxfilelock01/Makefile.am, psxgetrusage01/Makefile.am, psxid01/Makefile.am, psximfs01/Makefile.am, psximfs02/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxsignal06/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Remove obsolete optional manager capability.
2011-02-22Add HAVE_CONFIG_H.Ralf Corsepius1-0/+4
2010-07-062010-07-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill5-0/+133
* Makefile.am, configure.ac: Add test for various forms of times() and getrusage(). * psxgetrusage01/.cvsignore, psxgetrusage01/Makefile.am, psxgetrusage01/init.c, psxgetrusage01/psxgetrusage01.doc, psxgetrusage01/psxgetrusage01.scn, psxtimes01/.cvsignore, psxtimes01/Makefile.am, psxtimes01/init.c, psxtimes01/psxtimes01.doc, psxtimes01/psxtimes01.scn: New files.
