path: root/testsuites/psxtests/psxfenv01 (follow)
* libtest: <rtems/test.h> to <rtems/test-info.h>Sebastian Huber2020-07-231-1/+1
| | | | | | | | Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199.
* tests for fenv.h functionsEshan dhawan2020-06-063-26/+77
| | | | | | | | | | | | | | | | | | | | | added tests for fesetexeptflag(), fegetexeptflag(), fegetround(), fesetround(). In the test fegetround() does not return any flag other then FE_TONEAREST in tests. This is probably due to soft float. The test complies successfully and returns assert at fegetround() Other tests run without any errors tested on RISCV/rv32imac The test prints nothing if runs successfully. updates #2971 Signed-off-by: Eshan dhawan <eshandhawan51@gmail.com>
* config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORSSebastian Huber2019-12-191-1/+1
| | | | | | | Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753.
* psxfenv01: Check FE_DIVBYZERO defineSebastian Huber2019-11-121-0/+2
* Add psxfenv01 test to psxtestsVaibhav Gupta2019-09-103-0/+155
Note that this test requires a functional fenv implementation. Some targets have multilib variants where the fenv implementation is not 100% passing.
