The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
* psxfatal01/psxfatal01.scn, psxfatal01/testcase.h,
psxfatal02/psxfatal02.scn, psxfatal02/testcase.h,
psxfatal_support/init.c: Print proper begin and end message.
* psxfatal_support/init.c: Ensure that _Thread_BSP_context is
initialized.
PR 1606/cpukit
* psxfatal_support/init.c: Remove
INTERNAL_ERROR_INVALID_WORKSPACE_ADDRESS since it is not generated.
* psxfatal_support/init.c: Print end of test message in case of
success. Stop multitasking in the fatal error extension.
* psxfatal01/psxfatal01.scn, psxfatal02/psxfatal02.scn: Update.
* psxfatal_support/init.c: Remove references to ITRON constants.
* psxfatal_support/init.c, psxfatal_support/system.h: Eliminate use of
deprecated rtems_extension.
* include/pmacros.h, psx01/init.c, psx01/system.h, psx13/main.c,
psxbarrier01/main.c, psxchroot01/main.c, psxfatal_support/init.c,
psxfile01/main.c, psxfile01/test.c, psxmount/main.c, psxrdwrv/main.c,
psxreaddir/main.c, psxrwlock01/main.c, psxspin01/main.c,
psxstat/main.c, psxtime/main.c: Change TEST_INIT to CONFIGURE_INIT.
Make tmacros.h available to all POSIX tests. Add a clock_settime case
for < 1988.
* Makefile.am, configure.ac: New tests.
* psxfatal01/.cvsignore, psxfatal01/Makefile.am,
psxfatal02/.cvsignore, psxfatal02/Makefile.am,
psxfatal_support/init.c, psxfatal_support/system.h: New files.
