Fix link-time errors introduced by
e39cdb875ce7458787b0be173f2f7893a774a673.
Update #2531.
* psxenosys/init.c, psxenosys/psxenosys.doc,
psxenosys/psxenosys.scn: Remove devctl.
* psxenosys/init.c, psxenosys/psxenosys.scn: Update to reflect some of
aio being implemented.
* psxenosys/init.c, psxenosys/psxenosys.scn: Update to reflect AIO
submission.
* psxenosys/init.c: Include "pthread.h".
Conditionally add local prototype for pthread_atfork()
if pthread.h doesn't supply it.
* configure.ac: Check for sys/mman.h.
Check for mprotect in sys/mman.h.
* psxenosys/init.c: Conditionally add local prototype for
mprotect() if sys/mman.h doesn't supply it.
* psxclock/init.c, psxclock/psxclock.scn, psxenosys/init.c,
psxenosys/psxenosys.scn, psxsignal03/Makefile.am, psxsignal03/init.c,
psxsignal04/Makefile.am: Move test cases which needed to be executed
when POSIX is disabled to psxclock so they will be.
* psxenosys/init.c, psxenosys/psxenosys.scn: Add test of vfork stub.
* psx01/init.c, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c,
psx04/init.c, psx04/task1.c, psx04/task3.c, psx05/init.c,
psx06/init.c, psx07/init.c, psx08/init.c, psx09/init.c, psx11/task.c,
psx12/init.c, psx13/main.c, psx13/test.c, psxbarrier01/test.c,
psxcancel/init.c, psxcleanup/psxcleanup.c, psxenosys/init.c,
psxmsgq02/init.c, psxtime/main.c, psxtime/test.c,
psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Fix warnings.
* psxenosys/init.c, psxenosys/psxenosys.scn: Add test for stub
implementation mprotect().
* psxenosys/init.c: Fix typo.
* Makefile.am, configure.ac: New test to cover all RTEMS POSIX
functions that return ENOSYS.
* psxenosys/.cvsignore, psxenosys/Makefile.am, psxenosys/init.c,
psxenosys/psxenosys.scn, psxenosys/system.h: New files.
