2022-04-12 | testsuites/psxtests/psx[a-f]*: Change license to BSD-2 | Joel Sherrill | 2 | -6/+44 | |
Updates #3053. | |||||
2018-04-10 | testsuite/psxtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 1 | -21/+0 | |
This change is part of the testsuite Makefile.am reorganization. Update #3382 | |||||
2017-11-06 | tests: Use simple console driver | Sebastian Huber | 1 | -1/+1 | |
Update #3170. Update #3199. | |||||
2017-10-28 | tests: Remove TEST_INIT | Sebastian Huber | 1 | -2/+0 | |
The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | |||||
2017-10-23 | testsuite: Use printk for all test output where possible. | Chris Johns | 1 | -0/+2 | |
- Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | |||||
2017-10-05 | posix: Implement self-contained POSIX semaphores | Sebastian Huber | 1 | -1/+0 | |
For semaphore object pointer and object validation see POSIX_SEMAPHORE_VALIDATE_OBJECT(). Destruction or close of a busy semaphore returns an error status. The object is not flushed. POSIX semaphores are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3116. | |||||
2014-03-25 | tests/psxtests: Use <rtems/test.h> | Sebastian Huber | 1 | -2/+6 | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 2 | -2/+2 | |
2012-05-11 | psxtests - Eliminate missing prototype warnings | Joel Sherrill | 1 | -2/+9 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 3 | -9/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2012-05-07 | Revert: Remove CVS Ids | Joel Sherrill | 1 | -0/+4 | |
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | |||||
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | 1 | -4/+0 | |
2012-02-01 | Remove all .cvsignore files. | Joel Sherrill | 1 | -2/+0 | |
2011-12-08 | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -1/+1 | |
PR 1589/build * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am, psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am, psxaio03/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxclassic01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxeintr_join/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am, psxfile02/Makefile.am, psxfilelock01/Makefile.am, psxgetrusage01/Makefile.am, psxid01/Makefile.am, psximfs01/Makefile.am, psximfs02/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxsignal06/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Remove obsolete optional manager capability. | |||||
2011-09-30 | 2011-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* psx16/init.c, psxclassic01/init.c, psxeintr_join/init.c: Add HAVE_CONFIG_H. | |||||
2011-07-31 | 2011-07-31 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 5 | -0/+185 | |
PR 1855/cpukit * Makefile.am, configure.ac: Correct signal processing during pthread_join. We are supposed to unblock the thread waiting on a pthread_join(), dispatch the signal handler, account for it potentially overwriting errno, and then have the thread return to blocking within pthread_join(). * psxeintr_join/.cvsignore, psxeintr_join/Makefile.am, psxeintr_join/init.c, psxeintr_join/psxeintr_join.doc, psxeintr_join/psxeintr_join.scn: New files. |
