path: root/testsuites/psxtests/psxdevctl01 (follow)
* posix_devctl - Add support for SOCKCLOSEJoel Sherrill2020-01-174-2/+38
| | | | | | | | | The FACE Technical Standard, Edition 3.0 and later require the definition of the subcommand SOCKCLOSE in <devctl.h>. Reference: ​https://www.opengroup.org/face closes #3856.
* Move feature macro before "config.h" includeSebastian Huber2019-12-021-1/+2
| | | | | | | This allows to use header includes in "config.h" to reduce the build configuration checks. Update #3818.
* testsuite/psxtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-23/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* tests: Remove obsolete TESTS_USE_PRINTKSebastian Huber2017-10-281-1/+0
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-1/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* Add support for posix_devctl()Joel Sherrill2017-01-115-0/+181
