Updates #3053.
The FACE Technical Standard, Edition 3.0 and later require the definition
of the subcommand SOCKCLOSE in <devctl.h>.
Reference: ​https://www.opengroup.org/face
closes #3856.
* Makefile.am, configure.ac, fslink/fslink.doc, fslink/test.c,
fssymlink/test.c, imfs_fslink/Makefile.am,
imfs_fssymlink/Makefile.am, imfs_support/fs_config.h,
imfs_support/fs_support.c, mdosfs_support/fs_config.h,
mdosfs_support/fs_support.c, mimfs_fslink/Makefile.am,
mimfs_fssymlink/Makefile.am, mimfs_support/fs_config.h,
mimfs_support/fs_support.c, mrfs_fslink/Makefile.am,
mrfs_fssymlink/Makefile.am, mrfs_support/fs_config.h,
mrfs_support/fs_support.c, support/fstest.h,
support/fstest_support.c, support/fstest_support.h,
support/ramdisk_support.c, support/ramdisk_support.h: Submit correct
tarball of current work.
* fs01/init.c, fsfchx/fsfchx.doc, fsfchx/init.c, fsfile01/fsfile01.doc,
fsfile01/test.c, fsfile01/test_cat.c, fsfile01/test_extend.c,
fsfile01/test_write.c, fsfile02/fsfile02.doc, fsfile02/init.c,
fsfstest/fs-test.c, fsfstest/fsfstest.doc, fsimfs01/fsimfs01.doc,
fsimfs01/init.c, fsimfs02/fsimfs02.doc, fsimfs02/init.c,
fsmkdir/fsmkdir.doc, fsmkdir/test.c, fsopen/fsopen.doc,
fsopen/test.c, fsrdwrv/fsrdwrv.doc, fsrdwrv/test.c,
fsreaddir/fsreaddir.doc, fsreaddir/test.c, fsrename/fsrename.doc,
fsrename/test.c, fsrmdir/test.c, fsrwfile/fsrwfile.doc,
fsrwfile/init.c, fsstat/fsstat.doc, fsstat/test.c,
fstruncate/fstruncate.doc, fstruncate/test.c, imfs_fs01/.cvsignore,
imfs_fs01/Makefile.am, imfs_fs01/imfs_fs01.scn,
imfs_fsfchx/.cvsignore, imfs_fsfchx/Makefile.am,
imfs_fsfile01/.cvsignore, imfs_fsfile01/Makefile.am,
imfs_fsfile02/.cvsignore, imfs_fsfile02/Makefile.am,
imfs_fsfstest/.cvsignore, imfs_fsfstest/Makefile.am,
imfs_fsimfs01/.cvsignore, imfs_fsimfs01/Makefile.am,
imfs_fsimfs02/.cvsignore, imfs_fsimfs02/Makefile.am,
imfs_fslink/.cvsignore, imfs_fsmkdir/.cvsignore,
imfs_fsmkdir/Makefile.am, imfs_fsopen/.cvsignore,
imfs_fsopen/Makefile.am, imfs_fsrdwrv/.cvsignore,
imfs_fsrdwrv/Makefile.am, imfs_fsreaddir/.cvsignore,
imfs_fsreaddir/Makefile.am, imfs_fsrename/.cvsignore,
imfs_fsrename/Makefile.am, imfs_fsrmdir/.cvsignore,
imfs_fsrmdir/Makefile.am, imfs_fsrwfile/.cvsignore,
imfs_fsrwfile/Makefile.am, imfs_fsstat/.cvsignore,
imfs_fsstat/Makefile.am, imfs_fssymlink/.cvsignore,
imfs_fstruncate/.cvsignore, imfs_fstruncate/Makefile.am,
mdosfs_fsfchx/.cvsignore, mdosfs_fsfchx/Makefile.am,
mdosfs_fsfile01/.cvsignore, mdosfs_fsfile01/Makefile.am,
mdosfs_fsfile02/.cvsignore, mdosfs_fsfile02/Makefile.am,
mdosfs_fsfstest/.cvsignore, mdosfs_fsfstest/Makefile.am,
mdosfs_fsimfs01/.cvsignore, mdosfs_fsimfs01/Makefile.am,
mdosfs_fsimfs02/.cvsignore, mdosfs_fsimfs02/Makefile.am,
mdosfs_fslink/.cvsignore, mdosfs_fslink/Makefile.am,
mdosfs_fsmkdir/.cvsignore, mdosfs_fsmkdir/Makefile.am,
mdosfs_fsopen/.cvsignore, mdosfs_fsopen/Makefile.am,
mdosfs_fsrdwrv/.cvsignore, mdosfs_fsrdwrv/Makefile.am,
mdosfs_fsreaddir/.cvsignore, mdosfs_fsreaddir/Makefile.am,
mdosfs_fsrename/.cvsignore, mdosfs_fsrename/Makefile.am,
mdosfs_fsrmdir/.cvsignore, mdosfs_fsrmdir/Makefile.am,
mdosfs_fsrwfile/.cvsignore, mdosfs_fsrwfile/Makefile.am,
mdosfs_fsstat/.cvsignore, mdosfs_fsstat/Makefile.am,
mdosfs_fssymlink/.cvsignore, mdosfs_fssymlink/Makefile.am,
mdosfs_fstruncate/.cvsignore, mdosfs_fstruncate/Makefile.am,
mimfs_fs01/.cvsignore, mimfs_fs01/Makefile.am,
mimfs_fs01/mimfs_fs01.scn, mimfs_fsfchx/.cvsignore,
mimfs_fsfchx/Makefile.am, mimfs_fsfile01/.cvsignore,
mimfs_fsfile01/Makefile.am, mimfs_fsfile02/.cvsignore,
mimfs_fsfile02/Makefile.am, mimfs_fsfstest/.cvsignore,
mimfs_fsfstest/Makefile.am, mimfs_fsimfs01/.cvsignore,
mimfs_fsimfs01/Makefile.am, mimfs_fsimfs02/.cvsignore,
mimfs_fsimfs02/Makefile.am, mimfs_fslink/.cvsignore,
mimfs_fsmkdir/.cvsignore, mimfs_fsmkdir/Makefile.am,
mimfs_fsopen/.cvsignore, mimfs_fsopen/Makefile.am,
mimfs_fsrdwrv/.cvsignore, mimfs_fsrdwrv/Makefile.am,
mimfs_fsreaddir/.cvsignore, mimfs_fsreaddir/Makefile.am,
mimfs_fsrename/.cvsignore, mimfs_fsrename/Makefile.am,
mimfs_fsrmdir/.cvsignore, mimfs_fsrmdir/Makefile.am,
mimfs_fsrwfile/.cvsignore, mimfs_fsrwfile/Makefile.am,
mimfs_fsstat/.cvsignore, mimfs_fsstat/Makefile.am,
mimfs_fssymlink/.cvsignore, mimfs_fstruncate/.cvsignore,
mimfs_fstruncate/Makefile.am, mrfs_fsfchx/.cvsignore,
mrfs_fsfchx/Makefile.am, mrfs_fsfile01/.cvsignore,
mrfs_fsfile01/Makefile.am, mrfs_fsfile02/.cvsignore,
mrfs_fsfile02/Makefile.am, mrfs_fsfstest/.cvsignore,
mrfs_fsfstest/Makefile.am, mrfs_fsimfs01/.cvsignore,
mrfs_fsimfs01/Makefile.am, mrfs_fsimfs02/.cvsignore,
mrfs_fsimfs02/Makefile.am, mrfs_fslink/.cvsignore,
mrfs_fsmkdir/.cvsignore, mrfs_fsmkdir/Makefile.am,
mrfs_fsopen/.cvsignore, mrfs_fsopen/Makefile.am,
mrfs_fsrdwrv/.cvsignore, mrfs_fsrdwrv/Makefile.am,
mrfs_fsreaddir/.cvsignore, mrfs_fsreaddir/Makefile.am,
mrfs_fsrename/.cvsignore, mrfs_fsrename/Makefile.am,
mrfs_fsrmdir/.cvsignore, mrfs_fsrmdir/Makefile.am,
mrfs_fsrwfile/.cvsignore, mrfs_fsrwfile/Makefile.am,
mrfs_fsstat/.cvsignore, mrfs_fsstat/Makefile.am,
mrfs_fssymlink/.cvsignore, mrfs_fstruncate/.cvsignore,
mrfs_fstruncate/Makefile.am: Removed.
* Makefile.am, configure.ac, imfs_support/fs_config.h,
imfs_support/fs_support.c, mimfs_support/fs_config.h,
mimfs_support/fs_support.c: Add initial version of new filesystem
tests. There are multiple failures which need to be addressed by the
community.
* fsfchx/fsfchx.doc, fsfchx/init.c, fsfile01/fsfile01.doc,
fslink/fslink.doc, fslink/test.c, fsmkdir/fsmkdir.doc,
fsmkdir/test.c, fsopen/fsopen.doc, fsopen/test.c,
fsrdwrv/fsrdwrv.doc, fsrdwrv/test.c, fsreaddir/fsreaddir.doc,
fsreaddir/test.c, fsrename/fsrename.doc, fsrename/test.c,
fsrmdir/test.c, fsrwfile/fsrwfile.doc, fsrwfile/init.c,
fsstat/fsstat.doc, fsstat/test.c, fssymlink/fssymlink.doc,
fssymlink/test.c, fstruncate/fstruncate.doc, fstruncate/test.c,
imfs_fslink/.cvsignore, imfs_fslink/Makefile.am,
imfs_fsmkdir/.cvsignore, imfs_fsmkdir/Makefile.am,
imfs_fsopen/.cvsignore, imfs_fsopen/Makefile.am,
imfs_fsrdwrv/.cvsignore, imfs_fsrdwrv/Makefile.am,
imfs_fsreaddir/.cvsignore, imfs_fsreaddir/Makefile.am,
imfs_fsrename/.cvsignore, imfs_fsrename/Makefile.am,
imfs_fsrmdir/.cvsignore, imfs_fsrmdir/Makefile.am,
imfs_fsrwfile/.cvsignore, imfs_fsrwfile/Makefile.am,
imfs_fsstat/.cvsignore, imfs_fsstat/Makefile.am,
imfs_fssymlink/.cvsignore, imfs_fssymlink/Makefile.am,
mdosfs_support/fs_config.h, mdosfs_support/fs_support.c,
mimfs_fsfchx/.cvsignore, mimfs_fsfchx/Makefile.am,
mimfs_fsfile01/.cvsignore, mimfs_fsfile01/Makefile.am,
mimfs_fsfile02/.cvsignore, mimfs_fsfile02/Makefile.am,
mimfs_fsfstest/.cvsignore, mimfs_fsfstest/Makefile.am,
mimfs_fsimfs01/.cvsignore, mimfs_fsimfs01/Makefile.am,
mimfs_fsimfs02/.cvsignore, mimfs_fsimfs02/Makefile.am,
mimfs_fslink/.cvsignore, mimfs_fslink/Makefile.am,
mimfs_fssymlink/.cvsignore, mimfs_fssymlink/Makefile.am,
mimfs_fstruncate/.cvsignore, mimfs_fstruncate/Makefile.am,
mrfs_fsfchx/.cvsignore, mrfs_fsfchx/Makefile.am,
mrfs_fsfile01/.cvsignore, mrfs_fsfile01/Makefile.am,
mrfs_fsfile02/.cvsignore, mrfs_fsfile02/Makefile.am,
mrfs_fsfstest/.cvsignore, mrfs_fsfstest/Makefile.am,
mrfs_fsimfs01/.cvsignore, mrfs_fsimfs01/Makefile.am,
mrfs_fsimfs02/.cvsignore, mrfs_fsimfs02/Makefile.am,
mrfs_fslink/.cvsignore, mrfs_fslink/Makefile.am,
mrfs_fssymlink/.cvsignore, mrfs_fssymlink/Makefile.am,
mrfs_fstruncate/.cvsignore, mrfs_fstruncate/Makefile.am,
mrfs_support/fs_config.h, mrfs_support/fs_support.c,
support/fstest.h, support/fstest_support.c, support/fstest_support.h,
support/ramdisk_support.c, support/ramdisk_support.h: New files.
* Makefile.am, configure.ac, termios01/termios_testdriver.c: Do not use
CONSOLE_USE_INTERRUPTS. That is in use by BSPs and we should not use
it.
* termios02/.cvsignore, termios02/Makefile.am, termios02/init.c,
termios02/termios02.doc, termios02/termios02.scn: New files.
termios02 is a test for tcdrain().
* Makefile.am, configure.ac: Add test for timespec divide by zero.
* sp58/.cvsignore, sp58/Makefile.am, sp58/init.c, sp58/sp58.doc,
sp58/sp58.scn: New files.
* spfatal10/.cvsignore, spfatal10/Makefile.am, spfatal10/init.c,
spfatal10/spfatal10.doc, spfatal10/spfatal10.scn: New files.
* Makefile.am, configure.ac, spprintk/init.c, spprintk/spprintk.scn:
Enhance spprintk. Add two new fatal error tests to cover
__assert_func.
* spfatal11/.cvsignore, spfatal11/Makefile.am, spfatal11/init.c,
spfatal11/spfatal11.doc, spfatal11/spfatal11.scn: New files.
PR 1413/cpukit
* Makefile.am, configure.ac: Add test for case where server based
timers which reinitiated themselves did not get reinserted onto timer
chain.
* sp50/.cvsignore, sp50/Makefile.am, sp50/init.c, sp50/sp50.doc,
sp50/sp50.scn: New files.
PR 1347/cpukit
* Makefile.am, configure.ac, sp30/resume.c, sp30/task1.c, sp31/delay.c:
Rework Timer Server to ensure that the context allows for blocking,
allocating memory, and acquiring semaphores and mutexes.
* sp45/.cvsignore, sp45/Makefile.am, sp45/sp45.doc, sp45/sp45.scn:
New files.
* sp01/init.c, sp01/sp01.doc, sp01/system.h, sp01/task1.c, sp02/init.c,
sp02/preempt.c, sp02/sp02.doc, sp02/system.h, sp02/task1.c,
sp02/task2.c, sp02/task3.c, sp03/init.c, sp03/sp03.doc,
sp03/system.h, sp03/task1.c, sp03/task2.c, sp04/init.c,
sp04/sp04.doc, sp04/system.h, sp04/task1.c, sp04/task2.c,
sp04/task3.c, sp04/tswitch.c, sp05/init.c, sp05/sp05.doc,
sp05/system.h, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/init.c,
sp06/sp06.doc, sp06/system.h, sp06/task1.c, sp06/task2.c,
sp06/task3.c, sp07/init.c, sp07/sp07.doc, sp07/system.h,
sp07/task1.c, sp07/task2.c, sp07/task3.c, sp07/task4.c,
sp07/taskexit.c, sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c,
sp07/tstart.c, sp08/init.c, sp08/sp08.doc, sp08/system.h,
sp08/task1.c, sp09/delay.c, sp09/init.c, sp09/isr.c, sp09/screen01.c,
sp09/screen02.c, sp09/screen03.c, sp09/screen04.c, sp09/screen05.c,
sp09/screen06.c, sp09/screen07.c, sp09/screen08.c, sp09/screen09.c,
sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/screen13.c,
sp09/screen14.c, sp09/sp09.doc, sp09/system.h, sp09/task1.c,
sp09/task2.c, sp09/task3.c, sp09/task4.c, sp11/init.c, sp11/sp11.doc,
sp11/system.h, sp11/task1.c, sp11/task2.c, sp11/timer.c, sp12/init.c,
sp12/pridrv.c, sp12/pritask.c, sp12/sp12.doc, sp12/system.h,
sp12/task1.c, sp12/task2.c, sp12/task3.c, sp12/task4.c, sp12/task5.c,
sp13/fillbuff.c, sp13/init.c, sp13/putbuff.c, sp13/sp13.doc,
sp13/system.h, sp13/task1.c, sp13/task2.c, sp13/task3.c, sp14/asr.c,
sp14/init.c, sp14/sp14.doc, sp14/system.h, sp14/task1.c,
sp14/task2.c, sp15/init.c, sp15/sp15.doc, sp15/system.h,
sp15/task1.c, sp16/init.c, sp16/sp16.doc, sp16/system.h,
sp16/task1.c, sp16/task2.c, sp16/task3.c, sp16/task4.c, sp16/task5.c,
sp17/asr.c, sp17/init.c, sp17/sp17.doc, sp17/system.h, sp17/task1.c,
sp17/task2.c, sp19/first.c, sp19/fptask.c, sp19/fptest.h,
sp19/init.c, sp19/inttest.h, sp19/sp19.doc, sp19/system.h,
sp19/task1.c, sp20/getall.c, sp20/init.c, sp20/sp20.doc,
sp20/system.h, sp20/task1.c, sp21/init.c, sp21/sp21.doc,
sp21/system.h, sp21/task1.c, sp22/delay.c, sp22/init.c,
sp22/prtime.c, sp22/sp22.doc, sp22/system.h, sp22/task1.c,
sp23/init.c, sp23/sp23.doc, sp23/system.h, sp23/task1.c, sp24/init.c,
sp24/resume.c, sp24/sp24.doc, sp24/system.h, sp24/task1.c,
sp25/init.c, sp25/sp25.doc, sp25/system.h, sp25/task1.c, sp26/init.c,
sp26/sp26.doc, sp26/system.h, sp26/task1.c, sp30/init.c,
sp30/resume.c, sp30/sp30.doc, sp30/system.h, sp30/task1.c,
sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc,
sp31/system.h, sp31/task1.c, sp32/init.c, spfatal/fatal.c,
spfatal/init.c, spfatal/puterr.c, spfatal/spfatal.doc,
spfatal/system.h, spfatal/task1.c, spsize/getint.c, spsize/init.c,
spsize/size.c, spsize/system.h: URL for license changed.
* Added tests for task-based timers. This included the new tests
sp30 and sp31.
* Makefile.am, configure.ac: Modified to reflect new tests and files.
* sp09/screen14.c, sp09/sp09.scn: Modified to add error checks
for task-based timer services.
* sp30/.cvsignore, sp30/Makefile.am, sp30/init.c, sp30/resume.c,
sp30/sp30.doc, sp30/sp30.scn, sp30/system.h, sp30/task1.c,
sp31/.cvsignore, sp31/Makefile.am, sp31/delay.c, sp31/init.c,
sp31/prtime.c, sp31/sp31.doc, sp31/sp31.scn, sp31/system.h,
sp31/task1.c: New files.
