The FACE Technical Standard, Edition 3.0 and later require the definition
of the subcommand SOCKCLOSE in <devctl.h>.
Reference: ​https://www.opengroup.org/face
closes #3856.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
