brains GmbH.
This fixes a test failure on 64-bit systems with RTEMS_DEBUG enabled.
Updates #3053.
Updates #4625.
Do not adjust the stack area begin address since this may confuse the
stack allocator and result in failed stack frees.
Account for the alignment overhead in the stack space size estimate.
Check that the stack size is in the expected interval.
Update #4105.
Rename this header file to later move <t.h> to <rtems/test.h>. The main
feature provided by <rtems/test-info.h> is the output of standard test
information which is consumed by the RTEMS Tester.
Update #3199.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
The IO library used a POSIX key to store an optional POSIX user
environment pointer. This pulled in the POSIX keys support in every
application configuration. Add a user environment pointer to the thread
control block (TCB) instead. Applications which do not need the POSIX
user environment will just get an overhead of one pointer per thread.
Close #3882.
Update #3753.
This allows to use header includes in "config.h" to reduce the build
configuration checks.
Update #3818.
Do not rely on compiler optimizations to throw away empty loops.
Close #3673.
Update #2514.
Make CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE configurable by the user.
Update #3434.
This configuration is superfluous in these tests.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
Close #2895.
Turn pthread_spinlock_t into a self-contained object. On uni-processor
configurations, interrupts are disabled in the lock/trylock operations
and the previous interrupt status is restored in the corresponding
unlock operations. On SMP configurations, a ticket lock is a acquired
and released in addition.
The self-contained pthread_spinlock_t object is defined by Newlib in
<sys/_pthreadtypes.h>.
typedef struct {
struct _Ticket_lock_Control _lock;
__uint32_t _interrupt_state;
} pthread_spinlock_t;
This implementation is simple and efficient. However, this test case of
the Linux Test Project would fail due to call of printf() and sleep()
during spin lock ownership:
https://github.com/linux-test-project/ltp/blob/master/testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
There is only limited support for profiling on SMP configurations.
Delete CORE spinlock implementation.
Update #2674.
Update #2494.
Update #2555.
Account for the terminating null character. Use _POSIX_PATH_MAX instead
of NAME_MAX according to _POSIX_Semaphore_Manager_initialization() and
_POSIX_Message_queue_Manager_initialization().
The mq_open() function returns a descriptor to a POSIX message queue
object identified by a name. This is similar to sem_open(). In
contrast to the POSIX semaphore the POSIX message queues use a separate
object for the descriptor. This extra object is superfluous, since the
object identifier can be used directly for this purpose, just like for
the semaphores.
Update #2702.
Update #2555.
These tests intentionally use the deprecated method. Eventually
this code in the sections can be deleted.
Per task variables are inherently unsafe in SMP systems. This
patch disables them from the build and adds warnings in the
appropriate documentation and configuration sections.
Enable pthread_once() for all configurations. The pthread_once()
function is one means to initialize POSIX keys. Another use case is the
C++ support.
Implement the reeview changes.
Add a POSIX Fatal error domain.
Fix confdefs.h to correctly handle the internal POSIX mutexes.
Add rtems_resource_rtems_api, rtems_resource_posix_api,
rtems_resource_snapshot, rtems_resource_snapshot_equal(), and
rtems_resource_snapshot_check().
* psxconfig01/init.c: Create floating point tasks.
* psxconfig01/init.c: Create more objects.
* psxconfig01/init.c: Fix due to alignment issue.
* psxconfig01/.cvsignore, psxconfig01/Makefile.am, psxconfig01/init.c,
psxconfig01/psxconfig01.doc, psxconfig01/psxconfig01.scn: New files.
* Makefile.am, configure.ac: Reflect changes above.
