This test formerly had a bug in that it attempted to wait on a
condition variable with a Mutex that was not locked. This is
undefined by POSIX. But a recent change to match GNU/Linux behavior
resulted in finding a bug in the test.
* Makefile.am, configure.ac: Add new test to exercise error case for
when a task is blocked on a condition variable with one mutex and
another task attempts to block on the same condition variable with
another mutex.
* psxcond01/.cvsignore, psxcond01/Makefile.am, psxcond01/init.c,
psxcond01/psxcond01.doc, psxcond01/psxcond01.scn: New files.
