* | bsps/testsuites/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -6/+0 |
| | | | | Updates #4625. | ||||
* | testsuite/psxtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -19/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | psxtests/psxclockrealtime01: Fix warnings | Sebastian Huber | 2017-10-26 | 1 | -0/+2 |
| | | | | Update #3182. | ||||
* | testsuite: Fix build | Chris Johns | 2017-10-25 | 1 | -0/+2 |
| | | | | Updates #3170. | ||||
* | psxclockrealtime01: New test | Sebastian Huber | 2017-10-24 | 4 | -0/+698 |
Update #3182. |
