* | Move feature macro before "config.h" include | Sebastian Huber | 2019-12-02 | 1 | -2/+2 |
| | | | | | | | This allows to use header includes in "config.h" to reduce the build configuration checks. Update #3818. | ||||
* | testsuite/psxtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -23/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | posix: Change created_with_explicit_scheduler | Sebastian Huber | 2017-11-09 | 1 | -6/+62 |
| | | | | | | | | Remove POSIX_API_Control::created_with_explicit_scheduler. Add Thread_Control::was_created_with_inherited_scheduler. This fixes also pthread_getattr_np() for Classic tasks. Update #2514. | ||||
* | posix: Remove POSIX_API_Control::schedpolicy | Sebastian Huber | 2017-11-09 | 1 | -12/+14 |
| | | | | | | | Use the thread CPU budget algorithm to determine the scheduler policy. This fixes also pthread_getschedparam() for Classic tasks. Update #2514. | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | posix: Fix _POSIX_Threads_Create_extension() | Sebastian Huber | 2017-10-17 | 1 | -0/+8 |
| | | | | | | The thread POSIX API control must be fully initialized in _POSIX_Threads_Create_extension(), otherwise a pthread_setschedparam() is broken for all threads not created with pthread_create(). | ||||
* | psxclassic01: Assume correct pthread_detach() | Sebastian Huber | 2016-05-20 | 2 | -10/+31 |
| | | | | Update #2714. | ||||
* | tests/psxtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+6 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | psxtests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-11 | 1 | -3/+13 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am, psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am, psxaio03/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxclassic01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxeintr_join/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am, psxfile02/Makefile.am, psxfilelock01/Makefile.am, psxgetrusage01/Makefile.am, psxid01/Makefile.am, psximfs01/Makefile.am, psximfs02/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxsignal06/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-09-30 | 1 | -0/+3 |
| | | | | | * psx16/init.c, psxclassic01/init.c, psxeintr_join/init.c: Add HAVE_CONFIG_H. | ||||
* | 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-06-20 | 1 | -0/+1 |
| | | | | | | | | | | * Index: psxautoinit01/Makefile.am, psxbarrier01/Makefile.am, psxclassic01/Makefile.am, psxcleanup01/Makefile.am, psxfchx01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrwlock01/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am: Eliminate rtems_scn_DATA. Install *.doc to rtems_testsdir. | ||||
* | 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-06-20 | 1 | -1/+1 |
| | | | | * psxclassic01/psxclassic01.doc: Fix copyright date. | ||||
* | 2011-03-08 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-03-08 | 5 | -0/+218 |
PR 1759/cpukit * Makefile.am, configure.ac: Add test to use some pthread calls with Classic Tasks. * psxclassic01/.cvsignore, psxclassic01/Makefile.am, psxclassic01/init.c, psxclassic01/psxclassic01.doc, psxclassic01/psxclassic01.scn: New files. |
