Update #3753.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
* psxchroot01/main.c, psxmount/main.c, psxreaddir/main.c: Use
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER where needed.
* include/pmacros.h, psx01/init.c, psx01/system.h, psx13/main.c,
psxbarrier01/main.c, psxchroot01/main.c, psxfatal_support/init.c,
psxfile01/main.c, psxfile01/test.c, psxmount/main.c, psxrdwrv/main.c,
psxreaddir/main.c, psxrwlock01/main.c, psxspin01/main.c,
psxstat/main.c, psxtime/main.c: Change TEST_INIT to CONFIGURE_INIT.
Make tmacros.h available to all POSIX tests. Add a clock_settime case
for < 1988.
* psx02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx13/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxcancel/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxchroot01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxfile01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxmount/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxmsgq01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxreaddir/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxstat/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxtime/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxtimer/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
enable this support.
* include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c,
psx03/init.c, psx04/init.c, psx05/init.c, psx06/init.c, psx07/init.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx11/init.c,
psx12/init.c, psx13/Makefile.am, psx13/main.c, psx13/test.c,
psxcancel/init.c, psxchroot01/Makefile.am, psxchroot01/main.c,
psxchroot01/test.c, psxfile01/Makefile.am, psxfile01/main.c,
psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c,
psxfile01/test_write.c, psxmount/Makefile.am, psxmount/main.c,
psxmount/test.c, psxmsgq01/init.c, psxreaddir/Makefile.am,
psxreaddir/main.c, psxreaddir/test.c, psxsem01/init.c,
psxstat/Makefile.am, psxstat/main.c, psxstat/test.c, psxtime/main.c,
psxtime/test.c, psxtimer/psxtimer.c: Modified.
* Added once version of psxchroot01 test for user review.
* psxchroot01: New directory.
* psxchroot01/Makefile.am, psxchroot01/main.c, psxchroot01/test.c,
psxchroot01/psxchroot01.scn, psxchroot01/.cvsignore: New files.
* configure.in, Makefile.am: Modified to reflect above.
