psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am,
psxautoinit01/Makefile.am, psxautoinit02/Makefile.am,
psxbarrier01/Makefile.am, psxcancel/Makefile.am,
psxcancel01/Makefile.am, psxchroot01/Makefile.am,
psxcleanup/Makefile.am, psxcleanup01/Makefile.am,
psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am,
psxfatal01/Makefile.am, psxfatal02/Makefile.am,
psxfile01/Makefile.am, psxintrcritical01/Makefile.am,
psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am,
psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxmutexattr01/Makefile.am, psxobj01/Makefile.am,
psxpasswd01/Makefile.am, psxrdwrv/Makefile.am,
psxreaddir/Makefile.am, psxrwlock01/Makefile.am,
psxsem01/Makefile.am, psxsignal01/Makefile.am,
psxsignal02/Makefile.am, psxsignal03/Makefile.am,
psxsignal04/Makefile.am, psxsignal05/Makefile.am,
psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am,
psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am,
psxtimer01/Makefile.am, psxtimer02/Makefile.am,
psxualarm/Makefile.am, psxusleep/Makefile.am: Revert accidentally
committed patch.
* Makefile.am, configure.ac, psx01/Makefile.am, psx02/Makefile.am,
psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am,
psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am,
psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am,
psxalarm01/Makefile.am, psxautoinit01/Makefile.am,
psxautoinit02/Makefile.am, psxbarrier01/Makefile.am,
psxcancel/Makefile.am, psxcancel01/Makefile.am,
psxchroot01/Makefile.am, psxcleanup/Makefile.am,
psxcleanup01/Makefile.am, psxclock/Makefile.am,
psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfile01/Makefile.am, psxfile02/init.c,
psxfile02/psxfile02.doc, psxfile02/psxfile02.scn,
psxintrcritical01/Makefile.am, psxitimer/Makefile.am,
psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am,
psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am,
psxualarm/Makefile.am, psxusleep/Makefile.am: Add test for fd greater
than number of file descriptors configured.
* include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c,
psx03/init.c, psx03/task.c, psx04/init.c, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c,
psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c,
psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c,
psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c,
psxcancel01/init.c, psxchroot01/test.c, psxclock/init.c,
psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c,
psxfile01/test_write.c, psxitimer/init.c, psxkey01/task.c,
psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c,
psxmsgq03/init.c, psxmsgq04/init.c, psxreaddir/test.c,
psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c,
psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c,
psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c,
psxstack01/init.c, psxstat/test.c, psxtime/test.c, psxualarm/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
* psxbarrier01/test.c: Include <tmacros.h>
Add missing prototypes.
* psx01/init.c, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c,
psx04/init.c, psx04/task1.c, psx04/task3.c, psx05/init.c,
psx06/init.c, psx07/init.c, psx08/init.c, psx09/init.c, psx11/task.c,
psx12/init.c, psx13/main.c, psx13/test.c, psxbarrier01/test.c,
psxcancel/init.c, psxcleanup/psxcleanup.c, psxenosys/init.c,
psxmsgq02/init.c, psxtime/main.c, psxtime/test.c,
psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Fix warnings.
* include/pmacros.h, psx01/init.c, psx01/system.h, psx13/main.c,
psxbarrier01/main.c, psxchroot01/main.c, psxfatal_support/init.c,
psxfile01/main.c, psxfile01/test.c, psxmount/main.c, psxrdwrv/main.c,
psxreaddir/main.c, psxrwlock01/main.c, psxspin01/main.c,
psxstat/main.c, psxtime/main.c: Change TEST_INIT to CONFIGURE_INIT.
Make tmacros.h available to all POSIX tests. Add a clock_settime case
for < 1988.
* psxbarrier01/psxbarrier01.scn, psxbarrier01/test.c,
psxrwlock01/psxrwlock01.scn, psxrwlock01/test.c: Added several test
cases to improve test coverage.
* psxbarrier01/main.c: New file.
* Makefile.am, configure.ac: Adding POSIX barriers, POSIX spinlocks,
and partial implementation of POSIX rwlocks.
* psxbarrier01/.cvsignore, psxbarrier01/Makefile.am,
psxbarrier01/psxbarrier01.scn, psxbarrier01/test.c: New files.
