POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
Introduce map/unmap priority scheduler operations to map thread priority
values from/to the user domain to/from the scheduler domain. Use the
map priority operation to validate the thread priority. The EDF
schedulers use this new operation to distinguish between normal
priorities and priorities obtain through a job release.
Update #2173.
Update #2556.
for details.
PR 1589/build
psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am,
psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am,
psxaio03/Makefile.am, psxalarm01/Makefile.am,
psxautoinit01/Makefile.am, psxautoinit02/Makefile.am,
psxbarrier01/Makefile.am, psxcancel/Makefile.am,
psxcancel01/Makefile.am, psxchroot01/Makefile.am,
psxclassic01/Makefile.am, psxcleanup/Makefile.am,
psxcleanup01/Makefile.am, psxclock/Makefile.am,
psxcond01/Makefile.am, psxeintr_join/Makefile.am,
psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am,
psxfile02/Makefile.am, psxfilelock01/Makefile.am,
psxgetrusage01/Makefile.am, psxid01/Makefile.am,
psximfs01/Makefile.am, psximfs02/Makefile.am,
psxintrcritical01/Makefile.am, psxitimer/Makefile.am,
psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am,
psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am,
psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxmutexattr01/Makefile.am, psxobj01/Makefile.am,
psxpasswd01/Makefile.am, psxpasswd02/Makefile.am,
psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am,
psxrwlock01/Makefile.am, psxsem01/Makefile.am,
psxsignal01/Makefile.am, psxsignal02/Makefile.am,
psxsignal03/Makefile.am, psxsignal04/Makefile.am,
psxsignal05/Makefile.am, psxsignal06/Makefile.am,
psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am,
psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am,
psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am,
psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am:
Remove obsolete optional manager capability.
* psxautoinit01/Makefile.am, psxautoinit02/Makefile.am,
psxbarrier01/Makefile.am, psxrwlock01/Makefile.am,
psxspin01/Makefile.am, psxspin02/Makefile.am:
Remove scndir.
* Index: psxautoinit01/Makefile.am, psxbarrier01/Makefile.am,
psxclassic01/Makefile.am, psxcleanup01/Makefile.am,
psxfchx01/Makefile.am, psxpasswd01/Makefile.am,
psxpasswd02/Makefile.am, psxpipe01/Makefile.am,
psxrwlock01/Makefile.am, psxspin01/Makefile.am,
psxspin02/Makefile.am: Eliminate rtems_scn_DATA.
Install *.doc to rtems_testsdir.
psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am,
psxcleanup/Makefile.am, psxcleanup01/Makefile.am,
psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am,
psxfatal01/Makefile.am, psxfatal02/Makefile.am,
psxfile01/Makefile.am, psxintrcritical01/Makefile.am,
psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am,
psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxpasswd01/Makefile.am, psxrdwrv/Makefile.am,
psxreaddir/Makefile.am, psxrwlock01/Makefile.am,
psxsem01/Makefile.am, psxsignal01/Makefile.am,
psxsignal02/Makefile.am, psxsignal03/Makefile.am,
psxsignal04/Makefile.am, psxsignal05/Makefile.am,
psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am,
psxualarm/Makefile.am, psxusleep/Makefile.am: Revert accidentally
committed patch.
* Makefile.am, configure.ac, psx01/Makefile.am, psx02/Makefile.am,
psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am,
psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am,
psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am,
psxalarm01/Makefile.am, psxautoinit01/Makefile.am,
psxautoinit02/Makefile.am, psxbarrier01/Makefile.am,
psxcancel/Makefile.am, psxcancel01/Makefile.am,
psxchroot01/Makefile.am, psxcleanup/Makefile.am,
psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfile01/Makefile.am, psxfile02/init.c,
psxfile02/psxfile02.doc, psxfile02/psxfile02.scn,
psxualarm/Makefile.am, psxusleep/Makefile.am: Add test for fd greater
than number of file descriptors configured.
* Makefile.am, configure.ac: Add test of pthread mutex auto
intialization.
* psxautoinit01/.cvsignore, psxautoinit01/Makefile.am,
psxautoinit01/init.c, psxautoinit01/psxautoinit01.scn: New files.
