2014-12-16 | Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM | Sebastian Huber | 1 | -1/+0 | |
This define was superfluous, undocumented and used inconsistently. | |||||
2014-11-21 | Delete or rename MIN/MAX macros and defines | Sebastian Huber | 1 | -5/+5 | |
Include <sys/param.h> if necessary to get the MIN()/MAX() macros. | |||||
2014-03-25 | tests/psxtests: Use <rtems/test.h> | Sebastian Huber | 2 | -2/+6 | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 2 | -2/+2 | |
2012-05-11 | psxtests - Eliminate missing prototype warnings | Joel Sherrill | 1 | -0/+4 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -1/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2012-05-07 | Revert: Remove CVS Ids | Joel Sherrill | 1 | -0/+2 | |
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | |||||
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | 1 | -2/+0 | |
2012-02-01 | Remove all .cvsignore files. | Joel Sherrill | 1 | -2/+0 | |
2011-12-08 | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -3/+1 | |
PR 1589/build * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am, psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am, psxaio03/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxclassic01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxeintr_join/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am, psxfile02/Makefile.am, psxfilelock01/Makefile.am, psxgetrusage01/Makefile.am, psxid01/Makefile.am, psximfs01/Makefile.am, psximfs02/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxsignal06/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Remove obsolete optional manager capability. | |||||
2011-10-12 | 2011-10-12 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 1 | -1/+0 | |
* psxaio01/system.h, psxaio02/system.h, psxaio03/system.h: Do not use the stack checker. | |||||
2011-02-22 | Add HAVE_CONFIG_H. | Ralf Corsepius | 1 | -0/+4 | |
2011-02-15 | 2011-02-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -7/+19 | |
* psxaio03/init.c, psxaio03/psxaio03.scn: Run in a reasonable amount of time. Update screen. | |||||
2011-02-11 | Remove (Erroniously checked in). | Ralf Corsepius | 1 | -577/+0 | |
2011-01-17 | 2011-01-17 Alin Rus <alin.codejunkie@gmail.com> | Joel Sherrill | 6 | -0/+787 | |
* Makefile.am, configure.ac: Add psxaio03/. * psxaio03/Makefile.am, psxaio03/init.c, psxaio03/psxaio03.scn psxaio03/system.h: New. |
