* | testsuites/psxtests/psx[a-f]*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 2 | -6/+44 |
| | | | | Updates #3053. | ||||
* | testsuites: Remove CONFIGURE_MALLOC_STATISTICS | Sebastian Huber | 2020-03-31 | 1 | -4/+0 |
| | | | | | | This configuration option is obsolete since 2014. Update #1367. | ||||
* | config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS | Sebastian Huber | 2019-12-19 | 1 | -1/+1 |
| | | | | | | | Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753. | ||||
* | testsuite/psxtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -22/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | posix: Implement self-contained POSIX mutex | Sebastian Huber | 2017-10-05 | 1 | -1/+0 |
| | | | | | | | | POSIX mutexes are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3112. | ||||
* | posix: Implement self-contained POSIX condvar | Sebastian Huber | 2017-10-05 | 1 | -1/+0 |
| | | | | | | | | POSIX condition variables are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3113. | ||||
* | Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM | Sebastian Huber | 2014-12-16 | 1 | -1/+0 |
| | | | | This define was superfluous, undocumented and used inconsistently. | ||||
* | tests/psxtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 2 | -2/+6 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | Misc tests: Fix scn files and adjust output | Joel Sherrill | 2013-11-18 | 1 | -0/+31 |
* | psxtests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-11 | 1 | -0/+4 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -5/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+2 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -2/+0 |
* | psxaio01/psxaio02 - Formatting corrections | Joel Sherrill | 2012-05-03 | 1 | -9/+9 |
| | | | | | The file header was moved over one space. These two were the only files in the testsuite which did this. | ||||
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am, psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am, psxaio03/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxclassic01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxeintr_join/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am, psxfile02/Makefile.am, psxfilelock01/Makefile.am, psxgetrusage01/Makefile.am, psxid01/Makefile.am, psximfs01/Makefile.am, psximfs02/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxsignal06/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-10-12 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-10-12 | 1 | -1/+0 |
| | | | | | * psxaio01/system.h, psxaio02/system.h, psxaio03/system.h: Do not use the stack checker. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | 2010-11-01 Alin Rus <alin.codejunkie@gmail.com> | Joel Sherrill | 2010-11-01 | 1 | -52/+96 |
| | | | | * psxaio01/init.c, psxaio02/init.c: Improve coverage. | ||||
* | 2010-08-19 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-08-19 | 1 | -0/+2 |
| | | | | * psxaio01/.cvsignore, psxaio02/.cvsignore: New files. | ||||
* | 2010-08-16 Alin Rus <alin.codejunkie@gmail.com> | Ralf Corsepius | 2010-08-16 | 4 | -0/+226 |
* Makefile.am, configure.ac: Add psxaio01/, psxaio02/. * psxaio01/Makefile.am, psxaio01/init.c, psxaio01/psxaio01.scn, psxaio01/system.h: New. * psxaio02/Makefile.am, psxaio02/init.c, psxaio02/psxaio02.scn, psxaio02/system.h: New. |
