Threads may join the thread termination of another thread using the
pthread_join() or rtems_task_delete() directives. The thread cancel operation
used a special case priority boosting mechanism implemented by
_Thread_Raise_real_priority(). The problem was that this approach
* is not transitive,
* does not account for priority adjustments of the calling task
while waiting for the join,
* does not support clustered scheduling, and
* does not detect deadlocks.
All these problems are fixed by using a priority inheritance thread queue for
the join operation.
Close #4679.
Updates #3053.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3117.
Update #3182.
call to printk.
Updates #3170.
According to POSIX priority value returned from pthread_getschedparam()
shall be the value specified by the most recent pthread_setschedparam(),
pthread_setschedprio(), or pthread_create() call affecting the target
thread. Read this as though a temporary lower priority due to the
sporadic server policy shall not be visible through
pthread_getschedparam(). Thus, use rtems_task_set_priority() to get the
current priority of the threads.
Use a priority ceiling mutex to prevent sporadic server priority
adjustments.
Update #2738.
Update #2738.
for details.
PR 1589/build
psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am,
psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am,
psxaio03/Makefile.am, psxalarm01/Makefile.am,
psxautoinit01/Makefile.am, psxautoinit02/Makefile.am,
psxbarrier01/Makefile.am, psxcancel/Makefile.am,
psxcancel01/Makefile.am, psxchroot01/Makefile.am,
psxclassic01/Makefile.am, psxcleanup/Makefile.am,
psxcleanup01/Makefile.am, psxclock/Makefile.am,
psxcond01/Makefile.am, psxeintr_join/Makefile.am,
psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am,
psxfile02/Makefile.am, psxfilelock01/Makefile.am,
psxgetrusage01/Makefile.am, psxid01/Makefile.am,
psximfs01/Makefile.am, psximfs02/Makefile.am,
psxintrcritical01/Makefile.am, psxitimer/Makefile.am,
psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am,
psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am,
psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxmutexattr01/Makefile.am, psxobj01/Makefile.am,
psxpasswd01/Makefile.am, psxpasswd02/Makefile.am,
psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am,
psxrwlock01/Makefile.am, psxsem01/Makefile.am,
psxsignal01/Makefile.am, psxsignal02/Makefile.am,
psxsignal03/Makefile.am, psxsignal04/Makefile.am,
psxsignal05/Makefile.am, psxsignal06/Makefile.am,
psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am,
psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am,
psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am,
psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am:
Remove obsolete optional manager capability.
* psx01/init.c, psx07/init.c, psx09/init.c, psx12/init.c,
psxclock/init.c, psxtimer01/psxtimer.c: Include "pritime.h".
Use PRIdtime_t to print time_t.
PR 1867/cpukit
* Makefile.am, configure.ac, psx12/task.c, psxkey03/init.c,
psxrwlock01/test.c: Correct implementation of pthread_exit() and
pthread_join() to support the case where a thread is joinable but
calls pthread_exit() before a thread has attempted to join.
* psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c,
psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c,
psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c,
psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c,
psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c,
psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c,
psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c,
psxcancel01/init.c, psxchroot01/test.c, psxitimer/init.c,
psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c,
psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c,
psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c,
psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c,
psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c,
psxstack01/init.c, psxstack02/init.c, psxualarm/init.c: Eliminate
double space after parenthesis on rtems_test_assert().
psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am,
psxcleanup/Makefile.am, psxcleanup01/Makefile.am,
psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am,
psxfatal01/Makefile.am, psxfatal02/Makefile.am,
psxfile01/Makefile.am, psxintrcritical01/Makefile.am,
psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am,
psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxpasswd01/Makefile.am, psxrdwrv/Makefile.am,
psxreaddir/Makefile.am, psxrwlock01/Makefile.am,
psxsem01/Makefile.am, psxsignal01/Makefile.am,
psxsignal02/Makefile.am, psxsignal03/Makefile.am,
psxsignal04/Makefile.am, psxsignal05/Makefile.am,
psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am,
psxualarm/Makefile.am, psxusleep/Makefile.am: Revert accidentally
committed patch.
* Makefile.am, configure.ac, psx01/Makefile.am, psx02/Makefile.am,
psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am,
psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am,
psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am,
psxalarm01/Makefile.am, psxautoinit01/Makefile.am,
psxautoinit02/Makefile.am, psxbarrier01/Makefile.am,
psxcancel/Makefile.am, psxcancel01/Makefile.am,
psxchroot01/Makefile.am, psxcleanup/Makefile.am,
psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfile01/Makefile.am, psxfile02/init.c,
psxfile02/psxfile02.doc, psxfile02/psxfile02.scn,
psxualarm/Makefile.am, psxusleep/Makefile.am: Add test for fd greater
than number of file descriptors configured.
* include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c,
psx03/init.c, psx03/task.c, psx04/init.c, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c,
psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c,
psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c,
psxcancel01/init.c, psxchroot01/test.c, psxclock/init.c,
psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c,
psxfile01/test_write.c, psxitimer/init.c, psxkey01/task.c,
psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c,
psxmsgq03/init.c, psxmsgq04/init.c, psxreaddir/test.c,
psxstack01/init.c, psxstat/test.c, psxtime/test.c, psxualarm/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
* psx12/init.c: Include <sched.h>.
* psx01/init.c, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c,
psx04/init.c, psx04/task1.c, psx04/task3.c, psx05/init.c,
psx06/init.c, psx07/init.c, psx08/init.c, psx09/init.c, psx11/task.c,
psx12/init.c, psx13/main.c, psx13/test.c, psxbarrier01/test.c,
psxcancel/init.c, psxcleanup/psxcleanup.c, psxenosys/init.c,
psxmsgq02/init.c, psxtime/main.c, psxtime/test.c,
psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Fix warnings.
* psx05/init.c, psx07/init.c, psx09/init.c, psx11/init.c, psx12/init.c:
Run all tests successfully with maxixum number of priorities as 16
instead of 256. This was done by temporarily modifying the score
priority.h maximum. This allowed testing of all API code to ensure
that it worked properly with a reduced number of priorities. Most
modifications were to switch from hard-coded maximum to using the API
provided methods to determine maximum number of priority levels.
* psx02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx13/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxcancel/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxchroot01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxfile01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxmount/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxmsgq01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxreaddir/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxstat/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxtime/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxtimer/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* psx02/Makefile.am: Ditto.
* psx03/Makefile.am: Ditto.
* psx04/Makefile.am: Ditto.
* psx05/Makefile.am: Ditto.
* psx06/Makefile.am: Ditto.
* psx07/Makefile.am: Ditto.
* psx08/Makefile.am: Ditto.
* psx09/Makefile.am: Ditto.
* psx10/Makefile.am: Ditto.
* psx11/Makefile.am: Ditto.
* psx12/Makefile.am: Ditto.
* psx13/Makefile.am: Ditto.
* psxcancel/Makefile.am: Ditto.
* psxchroot01/Makefile.am: Ditto.
* psxfile01/Makefile.am: Ditto.
* psxmount/Makefile.am: Ditto.
* psxmsgq01/Makefile.am: Ditto.
* psxreaddir/Makefile.am: Ditto.
* psxsem01/Makefile.am: Ditto.
* psxstat/Makefile.am: Ditto.
* psxtime/Makefile.am: Ditto.
* psxtimer/Makefile.am: Ditto.
* include/Makefile.am: Reformat.
* psx01/Makefile.am: Remove all-local: $(ARCH).
* psx02/Makefile.am: Remove all-local: $(ARCH).
* psx03/Makefile.am: Remove all-local: $(ARCH).
* psx04/Makefile.am: Remove all-local: $(ARCH).
* psx05/Makefile.am: Remove all-local: $(ARCH).
* psx06/Makefile.am: Remove all-local: $(ARCH).
* psx07/Makefile.am: Remove all-local: $(ARCH).
* psx08/Makefile.am: Remove all-local: $(ARCH).
* psx09/Makefile.am: Remove all-local: $(ARCH).
* psx10/Makefile.am: Remove all-local: $(ARCH).
* psx11/Makefile.am: Remove all-local: $(ARCH).
* psx12/Makefile.am: Remove all-local: $(ARCH).
* psx13/Makefile.am: Remove all-local: $(ARCH).
* psxcancel/Makefile.am: Remove all-local: $(ARCH).
* psxchroot01/Makefile.am: Remove all-local: $(ARCH).
* psxfile01/Makefile.am: Remove all-local: $(ARCH).
* psxhdrs/Makefile.am: Remove all-local: $(ARCH).
* psxmount/Makefile.am: Remove all-local: $(ARCH).
* psxmsgq01/Makefile.am: Remove all-local: $(ARCH).
* psxreaddir/Makefile.am: Remove all-local: $(ARCH).
* psxsem01/Makefile.am: Remove all-local: $(ARCH).
* psxstat/Makefile.am: Remove all-local: $(ARCH).
* psxtime/Makefile.am: Remove all-local: $(ARCH).
* psxtimer/Makefile.am: Remove all-local: $(ARCH).
* psx01/init.c, psx01/system.h, psx01/task.c, psx02/init.c,
psx02/system.h, psx02/task.c, psx03/init.c, psx03/system.h,
psx03/task.c, psx04/init.c, psx04/system.h, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/system.h,
psx06/system.h, psx06/task.c, psx06/task2.c, psx07/init.c,
psx07/system.h, psx07/task.c, psx08/init.c, psx08/system.h,
psx08/task1.c, psx08/task2.c, psx08/task3.c, psx09/init.c,
psx09/system.h, psx10/init.c, psx10/system.h, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/system.h,
psx11/task.c, psx12/init.c, psx12/system.h, psx12/task.c,
psx13/main.c, psx13/test.c, psxcancel/init.c, psxfile01/main.c,
psxfile01/test.c, psxhdrs/clock01.c, psxhdrs/clock02.c,
psxhdrs/clock03.c, psxhdrs/clock04.c, psxhdrs/clock05.c,
psxhdrs/clock06.c, psxhdrs/cond01.c, psxhdrs/cond02.c,
psxhdrs/cond03.c, psxhdrs/cond04.c, psxhdrs/cond05.c,
psxhdrs/cond06.c, psxhdrs/cond07.c, psxhdrs/cond08.c,
psxhdrs/cond09.c, psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c,
psxhdrs/key03.c, psxhdrs/key04.c, psxhdrs/mutex01.c,
psxhdrs/mutex02.c, psxhdrs/mutex03.c, psxhdrs/mutex04.c,
psxhdrs/mutex05.c, psxhdrs/mutex06.c, psxhdrs/mutex07.c,
psxhdrs/mutex08.c, psxhdrs/mutex09.c, psxhdrs/mutex10.c,
psxhdrs/mutex11.c, psxhdrs/mutex12.c, psxhdrs/mutex13.c,
psxhdrs/mutex14.c, psxhdrs/mutex15.c, psxhdrs/mutex16.c,
psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c,
psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c,
psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c,
psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c,
psxhdrs/proc13.c, psxhdrs/proc14.c, psxhdrs/pthread01.c,
psxhdrs/pthread02.c, psxhdrs/pthread03.c, psxhdrs/pthread04.c,
psxhdrs/pthread05.c, psxhdrs/pthread06.c, psxhdrs/pthread07.c,
psxhdrs/pthread08.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c,
psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c,
psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c,
psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c,
psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c,
psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c,
psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c,
psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread31.c,
psxhdrs/pthread32.c, psxhdrs/pthread33.c, psxhdrs/pthread34.c,
psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/sched01.c,
psxhdrs/sched02.c, psxhdrs/sched03.c, psxhdrs/sched04.c,
psxhdrs/sched05.c, psxhdrs/sched06.c, psxhdrs/sched07.c,
psxhdrs/sched08.c, psxhdrs/signal01.c, psxhdrs/signal02.c,
psxhdrs/signal03.c, psxhdrs/signal04.c, psxhdrs/signal05.c,
psxhdrs/signal06.c, psxhdrs/signal07.c, psxhdrs/signal08.c,
psxhdrs/signal09.c, psxhdrs/signal10.c, psxhdrs/signal11.c,
psxhdrs/signal12.c, psxhdrs/signal13.c, psxhdrs/signal14.c,
psxhdrs/signal15.c, psxhdrs/signal16.c, psxhdrs/signal17.c,
psxhdrs/signal18.c, psxhdrs/signal19.c, psxhdrs/signal20.c,
psxhdrs/signal21.c, psxhdrs/signal22.c, psxhdrs/signal23.c,
psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c,
psxhdrs/time01.c, psxhdrs/time02.c, psxhdrs/time03.c,
psxhdrs/time04.c, psxhdrs/time05.c, psxhdrs/time06.c,
psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c,
psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c,
psxhdrs/time13.c, psxhdrs/timer01.c, psxhdrs/timer02.c,
psxhdrs/timer03.c, psxhdrs/timer04.c, psxhdrs/timer05.c,
psxhdrs/timer06.c, psxhdrs/timer07.c, psxmsgq01/init.c,
psxmsgq01/system.h, psxsem01/system.h, psxstat/main.c,
psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c,
psxtimer/system.h: URL for license changed.
psx01/Makefile.am: Reflect having moved automake.
psx02/Makefile.am: Reflect having moved automake.
psx03/Makefile.am: Reflect having moved automake.
psx04/Makefile.am: Reflect having moved automake.
psx05/Makefile.am: Reflect having moved automake.
psx06/Makefile.am: Reflect having moved automake.
psx07/Makefile.am: Reflect having moved automake.
psx08/Makefile.am: Reflect having moved automake.
psx09/Makefile.am: Reflect having moved automake.
psx10/Makefile.am: Reflect having moved automake.
psx11/Makefile.am: Reflect having moved automake.
psx12/Makefile.am: Reflect having moved automake.
psx13/Makefile.am: Reflect having moved automake.
psxcancel/Makefile.am: Reflect having moved automake.
psxchroot01/Makefile.am: Reflect having moved automake.
psxfile01/Makefile.am: Reflect having moved automake.
psxhdrs/Makefile.am: Reflect having moved automake.
psxmount/Makefile.am: Reflect having moved automake.
psxmsgq01/Makefile.am: Reflect having moved automake.
psxreaddir/Makefile.am: Reflect having moved automake.
psxsem01/Makefile.am: Reflect having moved automake.
psxstat/Makefile.am: Reflect having moved automake.
psxtime/Makefile.am: Reflect having moved automake.
psxtimer/Makefile.am: Reflect having moved automake.
