for details.
PR 1589/build
psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am,
psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am,
psxaio03/Makefile.am, psxalarm01/Makefile.am,
psxautoinit01/Makefile.am, psxautoinit02/Makefile.am,
psxbarrier01/Makefile.am, psxcancel/Makefile.am,
psxcancel01/Makefile.am, psxchroot01/Makefile.am,
psxclassic01/Makefile.am, psxcleanup/Makefile.am,
psxcleanup01/Makefile.am, psxclock/Makefile.am,
psxcond01/Makefile.am, psxeintr_join/Makefile.am,
psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am,
psxfile02/Makefile.am, psxfilelock01/Makefile.am,
psxgetrusage01/Makefile.am, psxid01/Makefile.am,
psximfs01/Makefile.am, psximfs02/Makefile.am,
psxintrcritical01/Makefile.am, psxitimer/Makefile.am,
psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am,
psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am,
psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxmutexattr01/Makefile.am, psxobj01/Makefile.am,
psxpasswd01/Makefile.am, psxpasswd02/Makefile.am,
psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am,
psxrwlock01/Makefile.am, psxsem01/Makefile.am,
psxsignal01/Makefile.am, psxsignal02/Makefile.am,
psxsignal03/Makefile.am, psxsignal04/Makefile.am,
psxsignal05/Makefile.am, psxsignal06/Makefile.am,
psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am,
psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am,
psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am,
psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am:
Remove obsolete optional manager capability.
* psx01/init.c, psx07/init.c, psx09/init.c, psx12/init.c,
psxclock/init.c, psxtimer01/psxtimer.c: Include "pritime.h".
Use PRIdtime_t to print time_t.
PR 1867/cpukit
* Makefile.am, configure.ac, psx12/task.c, psxkey03/init.c,
psxrwlock01/test.c: Correct implementation of pthread_exit() and
pthread_join() to support the case where a thread is joinable but
calls pthread_exit() before a thread has attempted to join.
* psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c,
psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c,
psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c,
psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c,
psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c,
psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c,
psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c,
psxcancel01/init.c, psxchroot01/test.c, psxitimer/init.c,
psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c,
psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c,
psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c,
psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c,
psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c,
psxstack01/init.c, psxstack02/init.c, psxualarm/init.c: Eliminate
double space after parenthesis on rtems_test_assert().
psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am,
psxcleanup/Makefile.am, psxcleanup01/Makefile.am,
psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am,
psxfatal01/Makefile.am, psxfatal02/Makefile.am,
psxfile01/Makefile.am, psxintrcritical01/Makefile.am,
psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am,
psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxpasswd01/Makefile.am, psxrdwrv/Makefile.am,
psxreaddir/Makefile.am, psxrwlock01/Makefile.am,
psxsem01/Makefile.am, psxsignal01/Makefile.am,
psxsignal02/Makefile.am, psxsignal03/Makefile.am,
psxsignal04/Makefile.am, psxsignal05/Makefile.am,
psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am,
psxualarm/Makefile.am, psxusleep/Makefile.am: Revert accidentally
committed patch.
* Makefile.am, configure.ac, psx01/Makefile.am, psx02/Makefile.am,
psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am,
psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am,
psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am,
psxalarm01/Makefile.am, psxautoinit01/Makefile.am,
psxautoinit02/Makefile.am, psxbarrier01/Makefile.am,
psxcancel/Makefile.am, psxcancel01/Makefile.am,
psxchroot01/Makefile.am, psxcleanup/Makefile.am,
psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfile01/Makefile.am, psxfile02/init.c,
psxfile02/psxfile02.doc, psxfile02/psxfile02.scn,
psxualarm/Makefile.am, psxusleep/Makefile.am: Add test for fd greater
than number of file descriptors configured.
* include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c,
psx03/init.c, psx03/task.c, psx04/init.c, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c,
psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c,
psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c,
psxcancel01/init.c, psxchroot01/test.c, psxclock/init.c,
psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c,
psxfile01/test_write.c, psxitimer/init.c, psxkey01/task.c,
psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c,
psxmsgq03/init.c, psxmsgq04/init.c, psxreaddir/test.c,
psxstack01/init.c, psxstat/test.c, psxtime/test.c, psxualarm/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
* psx12/init.c: Include <sched.h>.
* psx01/init.c, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c,
psx04/init.c, psx04/task1.c, psx04/task3.c, psx05/init.c,
psx06/init.c, psx07/init.c, psx08/init.c, psx09/init.c, psx11/task.c,
psx12/init.c, psx13/main.c, psx13/test.c, psxbarrier01/test.c,
psxcancel/init.c, psxcleanup/psxcleanup.c, psxenosys/init.c,
psxmsgq02/init.c, psxtime/main.c, psxtime/test.c,
psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Fix warnings.
* psx05/init.c, psx07/init.c, psx09/init.c, psx11/init.c, psx12/init.c:
Run all tests successfully with maxixum number of priorities as 16
instead of 256. This was done by temporarily modifying the score
priority.h maximum. This allowed testing of all API code to ensure
that it worked properly with a reduced number of priorities. Most
modifications were to switch from hard-coded maximum to using the API
provided methods to determine maximum number of priority levels.
* psx02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx13/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxcancel/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxchroot01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxfile01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxmount/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxmsgq01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxreaddir/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxstat/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxtime/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxtimer/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* psx02/Makefile.am: Ditto.
* psx03/Makefile.am: Ditto.
* psx04/Makefile.am: Ditto.
* psx05/Makefile.am: Ditto.
* psx06/Makefile.am: Ditto.
* psx07/Makefile.am: Ditto.
* psx08/Makefile.am: Ditto.
* psx09/Makefile.am: Ditto.
* psx10/Makefile.am: Ditto.
* psx11/Makefile.am: Ditto.
* psx12/Makefile.am: Ditto.
* psx13/Makefile.am: Ditto.
* psxcancel/Makefile.am: Ditto.
* psxchroot01/Makefile.am: Ditto.
* psxfile01/Makefile.am: Ditto.
* psxmount/Makefile.am: Ditto.
* psxmsgq01/Makefile.am: Ditto.
* psxreaddir/Makefile.am: Ditto.
* psxsem01/Makefile.am: Ditto.
* psxstat/Makefile.am: Ditto.
* psxtime/Makefile.am: Ditto.
* psxtimer/Makefile.am: Ditto.
* include/Makefile.am: Reformat.
* psx01/Makefile.am: Remove all-local: $(ARCH).
* psx02/Makefile.am: Remove all-local: $(ARCH).
* psx03/Makefile.am: Remove all-local: $(ARCH).
* psx04/Makefile.am: Remove all-local: $(ARCH).
* psx05/Makefile.am: Remove all-local: $(ARCH).
* psx06/Makefile.am: Remove all-local: $(ARCH).
* psx07/Makefile.am: Remove all-local: $(ARCH).
* psx08/Makefile.am: Remove all-local: $(ARCH).
* psx09/Makefile.am: Remove all-local: $(ARCH).
* psx10/Makefile.am: Remove all-local: $(ARCH).
* psx11/Makefile.am: Remove all-local: $(ARCH).
* psx12/Makefile.am: Remove all-local: $(ARCH).
* psx13/Makefile.am: Remove all-local: $(ARCH).
* psxcancel/Makefile.am: Remove all-local: $(ARCH).
* psxchroot01/Makefile.am: Remove all-local: $(ARCH).
* psxfile01/Makefile.am: Remove all-local: $(ARCH).
* psxhdrs/Makefile.am: Remove all-local: $(ARCH).
* psxmount/Makefile.am: Remove all-local: $(ARCH).
* psxmsgq01/Makefile.am: Remove all-local: $(ARCH).
* psxreaddir/Makefile.am: Remove all-local: $(ARCH).
* psxsem01/Makefile.am: Remove all-local: $(ARCH).
* psxstat/Makefile.am: Remove all-local: $(ARCH).
* psxtime/Makefile.am: Remove all-local: $(ARCH).
* psxtimer/Makefile.am: Remove all-local: $(ARCH).
* psx01/init.c, psx01/system.h, psx01/task.c, psx02/init.c,
psx02/system.h, psx02/task.c, psx03/init.c, psx03/system.h,
psx03/task.c, psx04/init.c, psx04/system.h, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/system.h,
psx06/system.h, psx06/task.c, psx06/task2.c, psx07/init.c,
psx07/system.h, psx07/task.c, psx08/init.c, psx08/system.h,
psx08/task1.c, psx08/task2.c, psx08/task3.c, psx09/init.c,
psx09/system.h, psx10/init.c, psx10/system.h, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/system.h,
psx11/task.c, psx12/init.c, psx12/system.h, psx12/task.c,
psx13/main.c, psx13/test.c, psxcancel/init.c, psxfile01/main.c,
psxfile01/test.c, psxhdrs/clock01.c, psxhdrs/clock02.c,
psxhdrs/clock03.c, psxhdrs/clock04.c, psxhdrs/clock05.c,
psxhdrs/clock06.c, psxhdrs/cond01.c, psxhdrs/cond02.c,
psxhdrs/cond03.c, psxhdrs/cond04.c, psxhdrs/cond05.c,
psxhdrs/cond06.c, psxhdrs/cond07.c, psxhdrs/cond08.c,
psxhdrs/cond09.c, psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c,
psxhdrs/key03.c, psxhdrs/key04.c, psxhdrs/mutex01.c,
psxhdrs/mutex02.c, psxhdrs/mutex03.c, psxhdrs/mutex04.c,
psxhdrs/mutex05.c, psxhdrs/mutex06.c, psxhdrs/mutex07.c,
psxhdrs/mutex08.c, psxhdrs/mutex09.c, psxhdrs/mutex10.c,
psxhdrs/mutex11.c, psxhdrs/mutex12.c, psxhdrs/mutex13.c,
psxhdrs/mutex14.c, psxhdrs/mutex15.c, psxhdrs/mutex16.c,
psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c,
psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c,
psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c,
psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c,
psxhdrs/proc13.c, psxhdrs/proc14.c, psxhdrs/pthread01.c,
psxhdrs/pthread02.c, psxhdrs/pthread03.c, psxhdrs/pthread04.c,
psxhdrs/pthread05.c, psxhdrs/pthread06.c, psxhdrs/pthread07.c,
psxhdrs/pthread08.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c,
psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c,
psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c,
psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c,
psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c,
psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c,
psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c,
psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread31.c,
psxhdrs/pthread32.c, psxhdrs/pthread33.c, psxhdrs/pthread34.c,
psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/sched01.c,
psxhdrs/sched02.c, psxhdrs/sched03.c, psxhdrs/sched04.c,
psxhdrs/sched05.c, psxhdrs/sched06.c, psxhdrs/sched07.c,
psxhdrs/sched08.c, psxhdrs/signal01.c, psxhdrs/signal02.c,
psxhdrs/signal03.c, psxhdrs/signal04.c, psxhdrs/signal05.c,
psxhdrs/signal06.c, psxhdrs/signal07.c, psxhdrs/signal08.c,
psxhdrs/signal09.c, psxhdrs/signal10.c, psxhdrs/signal11.c,
psxhdrs/signal12.c, psxhdrs/signal13.c, psxhdrs/signal14.c,
psxhdrs/signal15.c, psxhdrs/signal16.c, psxhdrs/signal17.c,
psxhdrs/signal18.c, psxhdrs/signal19.c, psxhdrs/signal20.c,
psxhdrs/signal21.c, psxhdrs/signal22.c, psxhdrs/signal23.c,
psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c,
psxhdrs/time01.c, psxhdrs/time02.c, psxhdrs/time03.c,
psxhdrs/time04.c, psxhdrs/time05.c, psxhdrs/time06.c,
psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c,
psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c,
psxhdrs/time13.c, psxhdrs/timer01.c, psxhdrs/timer02.c,
psxhdrs/timer03.c, psxhdrs/timer04.c, psxhdrs/timer05.c,
psxhdrs/timer06.c, psxhdrs/timer07.c, psxmsgq01/init.c,
psxmsgq01/system.h, psxsem01/system.h, psxstat/main.c,
psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c,
psxtimer/system.h: URL for license changed.
psx01/Makefile.am: Reflect having moved automake.
psx02/Makefile.am: Reflect having moved automake.
psx03/Makefile.am: Reflect having moved automake.
psx04/Makefile.am: Reflect having moved automake.
psx05/Makefile.am: Reflect having moved automake.
psx06/Makefile.am: Reflect having moved automake.
psx07/Makefile.am: Reflect having moved automake.
psx08/Makefile.am: Reflect having moved automake.
psx09/Makefile.am: Reflect having moved automake.
psx10/Makefile.am: Reflect having moved automake.
psx11/Makefile.am: Reflect having moved automake.
psx12/Makefile.am: Reflect having moved automake.
psx13/Makefile.am: Reflect having moved automake.
psxcancel/Makefile.am: Reflect having moved automake.
psxchroot01/Makefile.am: Reflect having moved automake.
psxfile01/Makefile.am: Reflect having moved automake.
psxhdrs/Makefile.am: Reflect having moved automake.
psxmount/Makefile.am: Reflect having moved automake.
psxmsgq01/Makefile.am: Reflect having moved automake.
psxreaddir/Makefile.am: Reflect having moved automake.
psxsem01/Makefile.am: Reflect having moved automake.
psxstat/Makefile.am: Reflect having moved automake.
psxtime/Makefile.am: Reflect having moved automake.
psxtimer/Makefile.am: Reflect having moved automake.
* psx01/psx01.scn, psx02/psx02.scn, psx03/psx03.scn, psx04/psx04.scn,
psx05/psx05.scn, psx06/psx06.scn, psx07/psx07.scn, psx08/psx08.scn,
psx09/psx09.scn, psx10/psx10.scn, psx11/psx11.scn, psx12/psx12.scn:
Per PR239 update the IDs in the various screens.
* psx01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx02/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx03/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx04/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx05/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx06/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx07/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx08/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx09/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx10/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx11/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx12/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx13/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxcancel/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxchroot01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxfile01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxhdrs/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxmount/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxmsgq01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxreaddir/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxsem01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxstat/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxtime/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxtimer/Makefile.am: Use .$(OBJEXT) instead of .o.
enable this support.
psx03/init.c, psx04/init.c, psx05/init.c, psx06/init.c, psx07/init.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx11/init.c,
psx12/init.c, psx13/Makefile.am, psx13/main.c, psx13/test.c,
psxcancel/init.c, psxchroot01/Makefile.am, psxchroot01/main.c,
psxchroot01/test.c, psxfile01/Makefile.am, psxfile01/main.c,
psxfile01/test_write.c, psxmount/Makefile.am, psxmount/main.c,
psxmount/test.c, psxmsgq01/init.c, psxreaddir/Makefile.am,
psxreaddir/main.c, psxreaddir/test.c, psxsem01/init.c,
psxstat/Makefile.am, psxstat/main.c, psxstat/test.c, psxtime/main.c,
psxtime/test.c, psxtimer/psxtimer.c: Modified.
* psx01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxcancel/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxchroot01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxfile01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxhdrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmount/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmsgq01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxreaddir/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxstat/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtime/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtimer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx11/Makefile.am: include leaf.am instead of leaf.cfg.
* psxcancel/Makefile.am: include leaf.am instead of leaf.cfg.
* psx02/Makefile.am: include leaf.am instead of leaf.cfg.
* psx13/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtime/Makefile.am: include leaf.am instead of leaf.cfg.
* psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx07/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtimer/Makefile.am: include leaf.am instead of leaf.cfg.
* psx10/Makefile.am: include leaf.am instead of leaf.cfg.
* psx08/Makefile.am: include leaf.am instead of leaf.cfg.
* psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg.
* psxfile01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx05/Makefile.am: include leaf.am instead of leaf.cfg.
* psx09/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmount/Makefile.am: include leaf.am instead of leaf.cfg.
* psxstat/Makefile.am: include leaf.am instead of leaf.cfg.
* psx12/Makefile.am: include leaf.am instead of leaf.cfg.
* psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg.
* psxsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx03/Makefile.am: include leaf.am instead of leaf.cfg.
* psx04/Makefile.am: include leaf.am instead of leaf.cfg.
* psx06/Makefile.am: include leaf.am instead of leaf.cfg.
psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am,
psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am,
psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am
psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am,
psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am:
Use AM_CPPFLAGS += instead of AM_CPPFLAGS =
