path: root/testsuites/psxtests/psx12 (follow)
* 2002-11-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-141-1/+1
| | | | | | | * psx01/psx01.scn, psx02/psx02.scn, psx03/psx03.scn, psx04/psx04.scn, psx05/psx05.scn, psx06/psx06.scn, psx07/psx07.scn, psx08/psx08.scn, psx09/psx09.scn, psx10/psx10.scn, psx11/psx11.scn, psx12/psx12.scn: Per PR239 update the IDs in the various screens.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/Makefile.am: Use .$(OBJEXT) instead of .o. * psx02/Makefile.am: Use .$(OBJEXT) instead of .o. * psx03/Makefile.am: Use .$(OBJEXT) instead of .o. * psx04/Makefile.am: Use .$(OBJEXT) instead of .o. * psx05/Makefile.am: Use .$(OBJEXT) instead of .o. * psx06/Makefile.am: Use .$(OBJEXT) instead of .o. * psx07/Makefile.am: Use .$(OBJEXT) instead of .o. * psx08/Makefile.am: Use .$(OBJEXT) instead of .o. * psx09/Makefile.am: Use .$(OBJEXT) instead of .o. * psx10/Makefile.am: Use .$(OBJEXT) instead of .o. * psx11/Makefile.am: Use .$(OBJEXT) instead of .o. * psx12/Makefile.am: Use .$(OBJEXT) instead of .o. * psx13/Makefile.am: Use .$(OBJEXT) instead of .o. * psxcancel/Makefile.am: Use .$(OBJEXT) instead of .o. * psxchroot01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxfile01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxhdrs/Makefile.am: Use .$(OBJEXT) instead of .o. * psxmount/Makefile.am: Use .$(OBJEXT) instead of .o. * psxmsgq01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxreaddir/Makefile.am: Use .$(OBJEXT) instead of .o. * psxsem01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxstat/Makefile.am: Use .$(OBJEXT) instead of .o. * psxtime/Makefile.am: Use .$(OBJEXT) instead of .o. * psxtimer/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-021-1/+1
| | | | | | | | | | | | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c, psx05/init.c, psx06/init.c, psx07/init.c, psx08/task3.c, psx09/init.c, psx10/init.c, psx11/init.c, psx12/init.c, psx13/Makefile.am, psx13/main.c, psx13/test.c, psxcancel/init.c, psxchroot01/Makefile.am, psxchroot01/main.c, psxchroot01/test.c, psxfile01/Makefile.am, psxfile01/main.c, psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c, psxfile01/test_write.c, psxmount/Makefile.am, psxmount/main.c, psxmount/test.c, psxmsgq01/init.c, psxreaddir/Makefile.am, psxreaddir/main.c, psxreaddir/test.c, psxsem01/init.c, psxstat/Makefile.am, psxstat/main.c, psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c: Modified.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx02/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx03/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx04/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx05/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx06/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx07/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx08/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx09/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx10/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx11/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx12/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx13/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxcancel/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxchroot01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxfile01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxhdrs/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxmount/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxmsgq01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxreaddir/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxsem01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxstat/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxtime/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxtimer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/Makefile.am: include leaf.am instead of leaf.cfg. * psx11/Makefile.am: include leaf.am instead of leaf.cfg. * psxcancel/Makefile.am: include leaf.am instead of leaf.cfg. * psx02/Makefile.am: include leaf.am instead of leaf.cfg. * psx13/Makefile.am: include leaf.am instead of leaf.cfg. * psxtime/Makefile.am: include leaf.am instead of leaf.cfg. * psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg. * psx07/Makefile.am: include leaf.am instead of leaf.cfg. * psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg. * psxtimer/Makefile.am: include leaf.am instead of leaf.cfg. * psx10/Makefile.am: include leaf.am instead of leaf.cfg. * psx08/Makefile.am: include leaf.am instead of leaf.cfg. * psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg. * psxfile01/Makefile.am: include leaf.am instead of leaf.cfg. * psx05/Makefile.am: include leaf.am instead of leaf.cfg. * psx09/Makefile.am: include leaf.am instead of leaf.cfg. * psxmount/Makefile.am: include leaf.am instead of leaf.cfg. * psxstat/Makefile.am: include leaf.am instead of leaf.cfg. * psx12/Makefile.am: include leaf.am instead of leaf.cfg. * psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg. * psxsem01/Makefile.am: include leaf.am instead of leaf.cfg. * psx03/Makefile.am: include leaf.am instead of leaf.cfg. * psx04/Makefile.am: include leaf.am instead of leaf.cfg. * psx06/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am
* 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-011-1/+1
| | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am, psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am: Use AM_CPPFLAGS += instead of AM_CPPFLAGS =
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-122-9/+9
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Moved pmacros.h to include not support/include.Joel Sherrill1999-11-231-1/+1
* Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-0/+44
| | | | to convert the psxtests directory from Makefile.in to Makefile.am.
* Updated copyright notice.Joel Sherrill1999-11-173-6/+3
* updated copyright to 1998Joel Sherrill1998-02-173-3/+3
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-083-6/+6
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-223-15/+15
* modified test to take into account change in default value ofJoel Sherrill1996-09-061-0/+5
| | | | | inheritsched pthread attribute from implicit to explicit scheduling parameters.
* filled in screenMark Johannes1996-08-231-0/+11
* new test to test scheduling policy and paremeter paths in pthread_create.Joel Sherrill1996-08-084-0/+223
