index
4.11
4.8
4.9
5
master
RTEMS Kernel, file-systems, drivers, BSPs, samples, and testsuite.
devel@rtems.org
summary
refs
log
tree
commit
diff
stats
log msg
author
committer
range
path:
root
testsuites
psxtests
psx10
follow
Commit message (
Collapse
Author
Age
Lines
Removed spaces.
Joel Sherrill
1998-12-03
1
-4
+0
Fixed screen to match actual output.
Joel Sherrill
1998-04-27
1
-3
+2
updated copyright to 1998
Joel Sherrill
1998-02-17
5
-5
+5
Fixed typo in the pointer to the license terms.
Joel Sherrill
1997-10-08
5
-10
+10
headers updated to reflect new style copyright notice as part
Joel Sherrill
1997-04-22
5
-25
+25
Fixed test to match change to pthread_cond_timedwait which now takes a wall
Mark Johannes
1996-09-12
1
-26
+32
time. Commented out calls to pthread_cond_wait and pthread_cond_timedwait without the mutex locked before calling.
Filled in screen
Mark Johannes
1996-08-23
1
-0
+60
Changed test 5 to test 10 at bottom
Mark Johannes
1996-08-23
1
-1
+1
Commented out the EINVAL for mutex not acquired befor cond_wait call
Mark Johannes
1996-08-22
1
-4
+9
system.h: added task3 and changed condition variable config to 1
Mark Johannes
1996-08-14
1
-1
+6
task3: added to test error case in Wait_support for lock on mutex
Mark Johannes
1996-08-14
1
-0
+46
init: added error case for wait timedwait, and wait support
Mark Johannes
1996-08-14
1
-8
+153
task_2: added comments and print statement for task exit
Mark Johannes
1996-08-13
1
-0
+1
task_1: added comments and print statement for task exit
Mark Johannes
1996-08-13
1
-0
+5
Init.c: added timewait case, added broadcast case
Mark Johannes
1996-08-13
1
-3
+28
task_1: added to handle cases of waiting tasks on condition variables
Mark Johannes
1996-08-12
1
-0
+60
system.h: added protoypes for task and task2, added mutex id, and task ids
Mark Johannes
1996-08-12
1
-1
+10
Init.c: added cases for signal, wait and broadcast
Mark Johannes
1996-08-12
1
-7
+26
Task2: new task for broadcast case
Mark Johannes
1996-08-12
1
-0
+46
Init: added pthread_cond_init with an attr non-NULL, initialized the attr again
Mark Johannes
1996-08-12
1
-0
+8
Init: added prliminary phtread_cond_init and destroy cases.
Mark Johannes
1996-08-12
1
-0
+9
system.h: added condition variable #define for 10 condition variables
Mark Johannes
1996-08-12
1
-0
+2
system.h: initial cvs
Mark Johannes
1996-08-09
1
-0
+53
Init: added condattr - destroy, init, set and get cases
Mark Johannes
1996-08-09
1
-5
+6
Init: Original file - tests for condition variables.
Mark Johannes
1996-08-08
1
-0
+94
